Question about Hamilton Beach StepSavor 38510 Indoor Grill
Varable heat power cord
The power cord for the 38510 was lost in shippment of house hold goods
  • 944 Answers
Follow this link and you can order one; http://www.hamiltonbeach.com/cgi-bin/main/co_disp/displ/pgname/replacements/strfnbr/20 Hope this helps :)
Posted on Mar 27, 2007
Dryer won't come on. Wire block burned. Wires test good. Heating coil lookes burned
A good heating element should have continuity. When the heating element breaks, there is no continuity between the heater terminals. But sometimes, the broken ends of the heating element can make contact with the metal heater housing (from vibration) and draw a large current, causing the symptoms you have described.
To confirm a "short" between the heating element and the heater housing, check for continuity between the housing and each heater terminal. (The shorted part of the heating element is usually welded to the housing.) Occasionally, the short will not be welded, but a visual inspection will verify (welding scars and black soot) that a short has occurred, intermittantly.
Replace the terminal block, heater, damaged internal wiring, and possibly the thermal fuse, thermostats, and power cord.
Good luck
Mar 06, 2017 | Dryers
Started drying load, dryer shut off. won't turn on. checked door, changed thermal fuse, checked breaker. still doesn't work. light also not on.
If this is an electric dryer, you may have lost half of the power supply to it. Unplug and remove the little cover plate above where the power cord enters the dryer. Look at the 3 screws holding on the power cord for burned/black looking or loose connections. If nothing wrong there, shut off house breaker and remove cover on house plug where you plug the dryer into and look for same type of issues.
Mar 17, 2015 | Kenmore series 70 80 90 Dryer Motor...
How to install pull cord?
take off cap then take out old pull cord once done get a cord long enough some will hanging out when recoil rewinds rope next there is hole in rewind pulley make sure you find it then hard part rewind spring on recoil till it stop hold tight the unwind 2 winds hold on tight next slip cord trough houseing and through pull hole put screw driver threw holes in threw rehousing that will hold in place the pulley not the cord take a lighter heat the cord up this will keep the knot in place grab cord remove screw driver from houseing hold cord tight pull cord until knot is seated next two pulley slowly let reciol wind rope in until it stops should be cord hanging out grab hiold of cord next to recoil hole pull out for two pulley revolution hold there install handle on rope tie knot heat knot with lighter your done cut off excess rope reinstall cap and completey down let me no if you have problem i will help im the red neck i like helping people
Aug 28, 2014 | Garden
Lost password for my netgear n300 wireless router how can i retrive
Best way is do a factory reset.Press and hold reset button during this procedure ,do not release the button until you are finished and you will be back to factory default.
1)Hold button 30 sec.
2)remove power cord hold 30 sec.
3)plug in power cord 30 sec.
You should now be in default factory mode,good tyo go.
Nov 09, 2013 | NetGear Computers & Internet
How to Replace Little Giant Water Wizard Utility Pump Power Cord
Yes, If it goes together it will come apart. If it is the one I'm thinking of if you take the base apart there will be through bolts that run through the whole pump, remove these I want to think there are some that are short and these hold the base to the motor but they may be behind the impeller. Be warey as I'm not sure. But once the through bolts are out you should be able to carefully remove the top. Some have very frail gaskets here so be gentel. Once you have the top free there will be a compression nut holding the cord before pulling cord through use a light sand paper to clean the cord so the part you pull through will be fresh enough to seal. Don't lube the cord this will keep it from sealing. Pull it hrough and make your repair and put it back together the way it came apart. Use a sharpie to mark the top and housing as you take it apart. When finished loop some cord through pump handel and tie it off so this takes the weight in the future to keep from having the same problem again. good luck
May 29, 2009 | Little Giant Pool Cover Pump Water Wizard...
Dryer is not heating up
Hi there
I think that you are going to need a new heating coil, sorry . I would contact your local appliance dealer to see how much a new one would cost.
best regards mike
Mar 24, 2009 | Kenmore Elite HE4 Electric Dryer
Frigidaire electric range fef336 heating elements not heating
Range does not heat (lights and timer do not operate).
This would indicate the range is not receiving the required 220 volts. Check house hold breakers or fuses, open wiring between the terminal block and the components, and the power cord.
Please leave a rating!
Jan 31, 2009 | Frigidaire FEF376 Electric Kitchen Range
Electric stove top and oven
hi
if neither the cooktop nor the oven works check your voltage. Is there 240 volts to the unit. Flip the breaker off and back on. If that doesn't work, with the unit unplugged, remove the cover where the stove cord is connected and check the connections
Good Luck!!!
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Totally lost power to HP 7110
Don't Worry the HP printer are deisgned to connect without the surg protector.
Try the steps mentioned bellow
Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
If This does not work in the power cord you will see a rectangle box like thing thats a apdptor, after plugging it to the power oulet for a couple of minitues, check and see if you can feel any heat in the adaptor if yes then the adaptor is good the power cord may be bad, so accordingly replce the power cord or adaptor:
For HP Parts check the link bellow:
http://partsurfer.hp.com/cgi-bin/spi/main
Good Luck
Oct 03, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Hamilton Beach StepSavor 38510 Indoor Grill Logo
570 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Marvin
Marvin
Angel Joseph Jr.
Angel Joseph Jr.
Dayton Computer
Dayton Computer
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
