Question about HP Photosmart C5180 All-In-One InkJet Printer
Out of Paper message?
I have an HP C5180 all-in-one.
I have had this printer for a year and everytime I try and print a picture, it will not pull the paper though and gives me the message "out of paper"
I returned one about a month after I bought it and it does it will this one too.
Anyone have a solution?
Thanks
  • 1 more comment
  • bgondo Nov 26, 2008
    don't know how to change from regular paper tray to the photo paper tray.
  • pharmerjess Nov 26, 2008
    Thank you for the help, it still does it, only when i print a picture.
  • Anonymous Jan 13, 2009
    Mine will not feed any paper........ says out of paper. Any ideas? I did take all the paper out and hand fed one piece in and it worked on the one page............
    Novelist:
  • 183 Answers
Solution:- Complete the following steps in the order provided. Step one: Reset the product Without turning the product off, remove the power cord from the back of the product. Wait 30 seconds and then plug the power cord into the back of the product. If the product is not already on, use the On button to turn it on. Step two: Check the condition of the paper and reload it Replace any paper that is ripped, dusty, curled, wrinkled, or bent. Note :- Use only plain, white, unused paper in the product until the issue is resolved. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed. Tap the stack of paper on a flat surface to align the edges. Make sure that the stack of paper to be loaded in the product is no smaller than 10 and no larger than 25 sheets of paper. Note:- Do not load too much paper in the product. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again. If the issue persists, continue with the next step. Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays. Open a document in the program being used to print. Click File , click Print , and then click Properties . The product Properties dialog box appears. Click the Paper/Quality tab. Choose the appropriate paper size from the Size is drop-down menu. Choose the appropriate paper type from the Type is drop-down menu. Click OK and then click OK again to print the document.. If the issue is not resolved, continue with the next section. Note:- If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened. Step four: If necessary, obtain the HP Paper Feed Cleaning Kit Locate the serial number on the product. If the third and fourth digits of the serial number are 56, 57, 58, 59, 5A, 5B, 5C, or 61 , then use one of the Contact HP links on this page to contact a support representative. If the product is still under warranty, the support representative will send a free HP Paper Feed Cleaning Kit (part number c9000-67901). If the product is no longer under warranty, this kit can be purchased from HP online. Click here for region/country ordering information. Figure 1: Serial number with third and fourth digit circled Out of Paper message? - c00743072.jpg If the third and fourth digits of the serial number are not listed, the special cleaning kit is not necessary. Continue with the next step. Note:- The HP Paper Feed Cleaning Kit requires the product to be connected to a computer running Windows 2000 or XP with a USB connection. If the product is not already connected with a USB cable, connect it before using the HP Paper Feed Cleaning Kit.
Posted on Oct 26, 2008
  • Inderpal Singh
    Inderpal Singh Oct 26, 2008
    Step five: Clean the rollers
    Turn off the product and
    unplug the power cord.
    Open the access door to gain
    access to the rollers. Depending on the model, this is usually the rear access
    door. See the product user guide for information about locating the
    rollers.
    Clean the rubber rollers with a lint-free cloth,
    lightly moistened with water.
    Note:- Distilled, filtered, or bottled water is recommended for
    cleaning the rollers. Tap water might contain contaminants that can damage the
    rollers.
    Make sure that any paper
    rollers that rest on the input tray, which are located behind the back rollers,
    are cleaned. A clean cotton swab, lightly moistened with water, might be
    necessary to reach these rollers.
    Close the access door and plug
    in the power cord.
    issue is not resolved, continue to the next step.
    Step six: Service the product
    If you have completed all the
    steps listed above and are still experiencing a problem, service the
    product.
    Cause
    Any of the following issues
    can cause the error message to appear:
    The paper trays are empty or
    overloaded.
    The paper is curled.
    The print side, or shiny side,
    of the paper is not loaded in the input tray face down.
    The paper might not be engaged
    with the feed rollers.
    The paper-width guide is
    pressed against the paper stack too tightly.
    The paper tray is not
    completely inserted into the product.
    print driver do not match the paper loaded in the paper tray.
    The rubber paper-feed rollers
    are coated with dust.
How can I print envelopes on my HP C5180. I've had it over 2 years and have never been able to get it to print any size envelopes. I always get a 'paper mismatch' message. HP tech support has never...
I tried all of the suggestions on here and nothing worked. My envelopes are 5x7.3. So, I finally just put in 5x7 and lo and behold, even though there truly was a paper mismatch this time since that was NOT the size of the envelopes, they printed. I did have to move the text boxes some to make them print correctly. So, I guess the solution for my printer is to actually mismatch the size of the paper/envelope so that you will NOT get the "paper mismatch" error message. Will it work on other size envelopes? I have no clue. This is the first time I've ever been able to print an envelope at all with this printer that I've had 2 or 3 years.
Dec 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
When asked to print my c5180 all in one ejects blank sheet of paper making no attempt to print
Just click below for more information;
s.gif » Macintosh: All-in-One Ejects Blank Page or Pages in Mac OS X V10.4
Mac OS X V10.4: A blank page or pages emerge from the product when it is turned on. s.gif » A Blank Page Prints at the Beginning of Every Print Job ...
A blank sheet of paper prints at the start of every print job. s.gif » Load Paper
Instructions on loading paper and envelopes. s.gif » When I Try Printing in Windows Vista, My Printer Is Not Available in the List of Printers ...
Windows Vista: The product does not appear in the printers folder when attempting to print on a network. s.gif » HP Photosmart C5180 All-in-One Printer: Manuals
... HP Customer Care | HP Photosmart C5180 All-in-One Printer | Product information HP Photosmart ... One Printer | Product information HP Photosmart C5180 All-in-One Printer: Manuals About these files: These
Hope this may help;
Regards,
VOTIT
Aug 23, 2008 | HP Office Equipment & Supplies
Paper jam
Open your printer and look carefully around the paper feed. Take out any torn peices of paper and try again. Try telling the printer to print a page without paper, and see if you get the same message, or if it changes to an ' out of paper' type message. If so, load it up with paper and see what you get.
May 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Vivera printer won't print
Take the cartridge out and clean the head with dry cloth and reinstall than then try.
also go to menu on the printer and out it back to factory settings.
Kevin
Feb 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 (wont accept photo paper but will normal paper)
Load the printer with the slick glossy paper face down. See if it will print.
Jun 06, 2017 | HP Photosmart C5180 All-In-One InkJet...
Paper error
It sounds like the photo paper tray has gone in.Lift the paper tray and pull the blue photo paper tray all the way till it stops. Then push it back in till it clicks into place. Try printing again.
Let me know if it works
Jun 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
624 people viewed this question
Ben Johnson
