Question about Vizio VO47L 47 in. LCD TV
How to replace lvds cable - Vizio VO47L 47 in. LCD TV
  • Vizio Master
  • 8,617 Answers
The LVDS cable has a small tab on either side of the connector which gets pressed in so the connector can be slid out of its socket.
Posted on Feb 11, 2012
Sony 32cx520 bravia screen or color problem .. ask lng po kung pano ... tnx
there is a problem in interface between panel & main system board through lvds cable there are six comman mode coiles between the lvds jack from system ic these common mode coils are opened & this problem is occer please changes these coiles which are very near to lvds jack after replacing your set problem is ok.
Jan 12, 2014 | Sony 32CX520 BRAVIA Multisystem LCD TV for...
Olevia 232 t12 lvds cable
It might be best to replace the LVDS cable along with T'Con.
Jul 09, 2013 | Televison & Video
Any tricks to replacing the LVDS cable in Samsing LNS4051DX/XAA
Its easy but be sure the set is unplugged. The LVDS has little tabs that are on each side of the metal connection when you press in on the tabs the lvds cable slides right out of the Tcon and the other end does the same on the main board. To plug it back in press in the side tabs and then slide it squarely into the socket on the TCon and then release the pins when the connection is all the way in. 2_13_2013_1_58_03_pm.jpg
Feb 13, 2013 | Samsung LN-S4051D 40 in. LCD Television
How do you clean the LVDS cable on a Phillips model TLX03210B television?
It will be best to replace it with a new one, rather than making experiments with it. It won't cost more.
Dec 18, 2012 | Televison & Video
Today my 55" vizio screen popped and then turned red. I unpluged and restarted everything and now the audio is on, the chanels change, but the screen is completely read. some images are readable.
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
Dec 09, 2012 | Vizio VO47L 47 in. LCD TV
Whats a LVDS cable
Low-voltage differential signaling (LVDS) Allows very fast transfer of signal. Used in LCD, some plasma TV,s and Monitors. If the cable is bad it cause many image display issues similar to the pic. More info about T-con Control Boards and LVDS cable
Feb 18, 2012 | Polaroid Televison & Video
My 32 inch Sceptre when I turn it on it is just white but I have sound. is there a way to fix this problem
check the LVDS cable and T-con . now you know it maybe the panel its self if you do replace the T-con and lvds cable.
Nov 04, 2010 | LG 32LD450 32 In. LCD HDTV
I need a lvds replacement cable for a ltv-32w3hd
try these kind of lvds cables,if some of them fit for your need.
Jul 02, 2009 | LG 50PG30 Plasma HDTV
Green tv picture
sounds like the lvds cable has glue on it (some did) the glue has to be removed or the lvds cable replaced
Oct 11, 2007 | Samsung LN-S4051D 40 in. LCD Television
Vizio VO47L 47 in. LCD TV Logo
455 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
