We have just bought a new computer with Windows 7 and cannot get any sound from the speakers on our Polyview V293 monitor. There is no place to connect a 3.5mm jack at the back of the monitor. There is a square hole with a lock illustration next to it. Does that mean the speakers are locked? If so how do I unlock them?
  • 1,684 Answers
The speaker input jack on the Polyview V293 is right next to the power jack on the bottom of the monitor
Posted on Feb 11, 2012
Testimonial: "Yes - thank you. I had the jack in the monitor all the time but had it plugged into the computer at the wrong place. Durrrr! Thanks again."
sandrew
  • 2961 Answers
SOURCE: No sound
if your monitor has speakers, and it should  built in; then you will see a separate lead with  green plug on the end of it which is to be located in the rear of your pc with the green marked socket.
If theres no lead, then there must be a connector on the rear of the monitor
Posted on Oct 22, 2007
  • 15 Answers
SOURCE: I need a power cord for a Polyview V293 computer
Check out ebay here:
http://shop.ebay.co.uk/?_from=R40&_trksid=p3907.m570.l1313&_nkw=Polyview+V293+&_sacat=See-All-Categories
Posted on Jul 06, 2010
ruwidperd372
  • 279 Answers
SOURCE: trying to find a video
try this link below to download the driver
http://www.driverstart.com/start592730.html
Posted on Aug 10, 2010
budmrtn
  • 11361 Answers
SOURCE: A Polyview V293 monitor suddenly stopped working
Well, common failure in the LCD monitor after a couple years are due to failed DC filter caps in the power supply as you can see in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 21, 2010
Hi, I have a Polyview V293 LCD Monitor with a power supply output of 19v 3.42A. The power supply has failed. Most i have found being offered as direct replacement for this monitor have an output of 19v...
If the power adapter is a separate from the monitor then check the monitor's label on the back of the screen for the power rating.If the rating on the label is greater than 3.16A then I would not purchase this adapter.
I suggest you purchase an adapter with a current rating greater than what is stated on the monitor's label.
Check out this WEB site for power adapters - a 19Volt 90 watt = 4.7A power supply is suitable.
http://www.cheaperoz.com/z/result.jsp?ga=sc1&q=19v+power+adapter
Apr 01, 2011 | Amptron POLYVIEW 19" Monitor
A Polyview V293 monitor suddenly stopped working and fails to show any activity at all. There was no trauma at the time. Is this likely to be able to be repaired? Bruce Jones, Australia
Oct 20, 2010 | Amptron POLYVIEW 19" Monitor
Does it have a builtin microphone
Yes this monitor has a built in speaker on it, here is the complete details about this monitor.<br /><a href="http://www.newegg.com/Product/Product.aspx?Item=N82E16824024506&amp;SortField=0&amp;SummaryType=0&amp;PageSize=10&amp;SelectedRating=-1&amp;VideoOnlyMark=False&amp;IsFeedbackTab=true#scrollFullInfo">http://www.newegg.com/Product/Product.aspx?Item=N82E16824024506&amp;SortField=0&amp;SummaryType=0&amp;PageSize=10&amp;SelectedRating=-1&amp;VideoOnlyMark=False&amp;IsFeedbackTab=true#scrollFullInfo</a><br /><br />
Aug 26, 2010 | Polyview V17E 17" LCD Flat Panel Monitor
Trying to find a video device driver for an Amptron Polyview V293
Aug 10, 2010 | Amptron POLYVIEW 19" Monitor
I recently bought a Windows 7 64 bit PC. I have Optiquest monitor with built-in speakers. The sound was working fine and then it stoppped. I tried stand-alone speakers, then anoither monitor with speakers-...
Go into control panel / sounds / sounds and audio / select audio blind / should see a driver listed in each device. Back to sounds blind /test sound, if you can see the black arrow but its greyed out then driver is faulty. If you can click on it and it changes baxk to th esquare all is OK, ensure the sound jack is plugged into the GREEN ones at rear PC. Also check in volume blind that speakers are selected.
Feb 24, 2010 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
No sound monitor speakers
hmm the monitor is connecting to the pc sound card ...and for that you have to have a sound driver installed...if you know what kinda pc you have its easy ..but if its a built one ..you gonna either look inside to see what is the sound card name ...or try to see if you have a previous sound driver installation .....if you did had sound or still have on the ear pieces you have to have on the monitor too..just see the volume ...and the cable connection ..if it has a separate one (3.2 jack )or it connects directly with a HD cable
Aug 03, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview v17e - microphone?
G'day Matt,
No microphone. It has a line in socket to drive the stereo speakers.
cheers,
dave.
Jul 03, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
No sound
Oct 22, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Computers & Internet Logo
175 people viewed this question
David Payne
David Payne
