My westinghouse LT819s machine keeps giving me a 3f error. Always on the final spin cycle. I have replaced the pump so it is not a water draining problem. If I leave the machine a few hours and turn it on it will resume all OK but if I do another load after that it happens again
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
  • 1294 Answers
SOURCE: kenmore front load washer wont drain gives F2 error
There is an awesome guy on fixya with this:
http://www.fixya.com/support/r622155-kenmoreelitewhirlpoolduetdoorjammed
http://www.fixya.com/support/r615354-fherrorcodewhirlpoolduetkenmore
Posted on Mar 28, 2009
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
Posted on Oct 05, 2009
Bosch 300 Nexxt model with an e13 error code. Always drains fine but will not go into final spin.
so ur saying it will go into spin if u move timer manually? Leads me to believe u have a timer sticking issue?
Mar 09, 2015 | Bosch Washing Machines
Bush WM-1270 TVE error 2
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 24, 2013 | Washing Machines
WMA36 washer going through wash cycle then stops can turn knob to rinse and spin and only sometimes it will then work. Otherwise it just keeps rinsing and not draining much and sometimes not spinning!
Jan 19, 2013 | Hotpoint Wma32p Wma34p Wma36p Washing...
Washer will not spin
Jan 17, 2013 | Washing Machines
Washer agitates but does not spin
tI is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jun 12, 2012 | Estate Washing Machines
We have a fisher and paykel wl80t65cw1 washing machine which keeps coming up with error 130. What does this mean?
Thank you for using fixya.
Sep 01, 2011 | Fisher Washing Machines
The water does not always shut off and keeps filling the machine
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Aug 08, 2011 | Hoover HTC243 Top Load Washer
Hello, my washer does not spin dry, instead it starts back washing after the water is pumped out. on all the cycles this is happening. what should i do.
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 01, 2011 | Westinghouse WWS833ES Super Capacity Top...
I have a westinghouse washing machine LT819S with error code 3f any segestion how to fix
If water is not filling then it can be the failure of the inlet valve, if water fills but does not stop the error can be the water level sensor and if the motor does not work with voltage to the motor, it is failure of the motor.
However if there is no response at all then the control board is faulty.
Sep 13, 2010 | Washing Machines
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Feb 12, 2010 | LG WM2487HA Washer
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
