Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Curved Images - top & bottom of screen
The top and bottom edges of the screen will curve and are blurred slightly with red, green and yellow outlines. It does it right when you turn the TV on and will do it for a couple of minutes, correct, then do it for another couple of minutes and then correct after it's seemingly warmed up. We have had this TV for 8 years and this is the first problem we've had. Is there an easy fix for this or does it mean something major is getting ready to go out?
Thanks!
    Top Expert:
  • Mitsubishi Master
  • 75,581 Answers
Misaligned pin cushion adjustment, of damaged component/s at this stage circuit inside. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Jun 05, 2017
Shuttle83
  • 1139 Answers
SOURCE: WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 15, 2007
  • 1527 Answers
SOURCE: Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
Posted on May 08, 2009
  • 668 Answers
SOURCE: Mitsubishi 1080 hd series 65" Curved picture
The problem is the convergence circuit.
Mitsubishi used two different types of convergence IC's in this series. The first is a pair of STK-392-570, the second is a single STK393-110. The only way to fix the problem is to replace the appropriate IC'S. In some cases the problem may appear to be intermitent or loose solder connections. Save yourself the anguish and replace the IC'S.
Getting the PowerSupply/ Convergence board
out to do this is tricky and I recommend a professional to do it. Hidden screws on the front of the heat-sink make it difficult to take out and you can break the board easily trying to force it.
Posted on Jun 17, 2009
  • 90 Answers
SOURCE: Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Posted on Jul 08, 2009
SOURCE: Picture is curved whe you turn on the tv.
I have a ws55809 and having a picture issue until it warms up. appears out of focus with color bars on each side. It seams to be getting worse. Last time i turned it on it also had w jerky picture with fine horzontal lines.
Posted on Aug 22, 2009
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Blue curved line at top of screen and yellow curved line at botto
Do you by chance have any speakers sitting on top of the tv or right beside it. Speakers are unshielded and will cause this effect.
Feb 03, 2009 | Televison & Video
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
Blurry Curved Picture
Convergence IC's need to be replaced...change them both..
part # STK392-560.....Check soldered-in fuses...........T.
Dec 25, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
