Question about Singer Sewing Machines
Singer Athena 2009 needle hitting plastic in bobbin case
My husband gave me a Singer Athena 2009 that needs a little bit of work (he got an amazing deal on it new-ish in the box). I think it needs to be re-timed, but can't find directions anywhere on how to do it. I have removed the plate, the bobbin, and the black bobbin holder. Everything moves as it should, but when the needle gets to the bottom of it's path it hits the edge of the white plastic piece in the very bottom of the bobbin case. Any help or tips would be appreciated! I will take it in if necessary, but I would love to learn how to do this myself.
  • Singer Master
  • 7,365 Answers
Here's something to check
is the needle inserted all the way in to the needle holder?
needle--flat side goes to the back of the machine
is the needle clamp screw tight or loose?
if the needle is correctly in the needle holder & the needle clamp screw is tight --then the needle bar is out of time & need to be serviced
IF YOU DO HAVE TO TAKE IT TO BE SERVICED AFTER YOU GET IT HOME STOP RIGHT THEN & SEW ON THE MACHINE TO MAKE SURE THEY FIXED THE MACHINE & IT SEWS LIKE IT SUPPOSE TO, I HAD ONE CUSTOMER THAT TOOK THEIR MACHINE TO A SHOP & THEY CLEANED IT AGAIN & DIDN'T FIX IT BUT CHARGED THEM FOR IT & THEY BROUGHT IT TO ME TO FIX & IT HAD TO BE RETIME
did you get a instruction manual for the machine if not check at singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number---2009
Click search--if you don't see a manual--contact singer customer service
Posted on Feb 11, 2012
SOURCE: singer 1060
slide open metal plate, there is a little white finger button with a target symbol on it just to the left. Slide this all the way left, leaving plate OPEN. If your top needle is threaded correctly, you should now be able to push the foot pedal to sew adn the bobbin will refill. make sure not to go past the outer white line on the bobbin case. good luck. the target button will go back to the original position when you slide the plate closed.
Posted on Jan 05, 2009
  • 323 Answers
SOURCE: my singer athena 2000 won't
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
Posted on Aug 29, 2008
  • 10865 Answers
SOURCE: How do I fill a bobbin on a Singer 2000 Athena
http://www.singerco.com/accessories/manuals.html
go to this site to obtain the manual.
please mark this answer as a fixya!
Posted on Feb 27, 2009
  • 980 Answers
SOURCE: I have a Singer 6235 and all of a sudden when I
Make sure the needle is no bent or blunt, I can attach timing instructions if you email me drivewithken@blueyonder.co.uk
Posted on Nov 01, 2009
  • 1788 Answers
SOURCE: what is the secret to getting the bobbin holder
Download your manual for free at www.singerco.com and enlarge the diagram, it will be alot easier to see. Good luck
Posted on Nov 02, 2010
How do i thread the bobbin on a singer athena 1200 sewing machine
The Athena 1200 and 2000 are "Touch and Sew" slant needle machines. Singer has not made them for many years, but I always loved them, because the bobbin is wound in place--you don't take it out! You can still get a full assortment of presser feet for them; just make sure they're for slant needle machines.
You would be wise to visit the Singer Sewing Machine site and download your user's manual--it's free, and it will show you how to wind the bobbin. There are a series of pictures there as well. There are several steps you need to take, such as raising the presser foot, selecting the blind hem stitch, etc. Sounds complicated, but I owned an Athena 1200, and I can tell you that after the first or second try, you'll find it quite easy.
Incidentally, did you know that it's one of those rare machines that will do a TRUE 1/2" basting stitch! I kept it for years, just for that ability!
Feb 20, 2015 | Singer Sewing Machines
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
Threading bobbin singer athena 2009
Sorry... hate to say it but modern home singers are $%#&*@.
Have you tried a new bobbin? If the "spindle" spins... the bobbin should spin. Maybe your bobbin is busted or something?
Aug 02, 2012 | Singer Sewing Machines
New Problem...I have a Singer CG-550. When I try and sew anything, the needle hits something inside where the bobbin is. The little black casing holing the bobbin keeps moving all over the place, I slip...
On the right of the black bobbin case there are two screws, you can slacken those screws off and move the bobbin case nearer to the guard leaving enough room for the thread to pass through, if the needle is hitting the bottom you may need to retime the machine.
Mar 06, 2010 | Singer Sewing Machines
My needle keeps hitting the plastic bobbin holder - how can I fix this? Is the bobbin holder inserted wrong?
change the needle and see if it is still hitting because once they hit the case or the feed dog they very often get bent always change needles with different fabrics and types of thread
Dec 12, 2009 | Singer Quantum 7350 Mechanical Sewing...
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Singer 1060
Aug 20, 2008 | Singer 1120 Mechanical Sewing Machine
A horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Jan 05, 2007 | Singer 2662
Sewing Machines Logo
446 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
