Question about Samsung Digimax 301 Digital Camera
Camera turns off even with new batteries in it. help pls.
I have had the camera for a little while now. but the camera started doing it a little after the warrenty went out. what it does is when i power the camera on it will stay on for only a few seconds then a blue screen comes up and says low battery then it powers off. i can keep turning it on over and over and it does the same thing. i have tried all differnt type of batteries. tried someone's rechargeable ones. and all kinds of differnt AA ones bought from the store. i have even taken the camera apart just to see if anything looked out of line or burnt on the chip board and nothing looked wrong. can someone please help me.
Hi gras, [Samsung Digimax 301] My camera also went dead on me, just can not turn it on. Please help with instruction on how to open it. I have removed 10 screws but the camera can not open completly.
Posted on Nov 06, 2006
I put in new batteries in but 5 mins later it says low battery and turns itself off.
I have the same problem. Canon support claims they have never had this problem before, but it is all over the Internet. I won't be buying another Canon for the support, although the camera is sweet.
I have tested everything I can see including the batteries and there's nothing wrong with the batteries.
However, when I eyeball the height of the batteries, I see that one is lower than the others. So I assume that this connection is not as solid as the rest and may be why low battery indicator shows even when the batteries are testing fully charged.
On the SX20 you can't bend down the terminals at the top, so you have to reach in to the bottom and bend the contacts on the short battery up. I believe that this is just a temporary solution because it doesn't fix my camera permanently.
But try it. It is a free fix and can't hurt.
IMHO
Apr 11, 2012 | Canon PowerShot SX20 IS Digital Camera
Sanyo VPC-E90 Turns off then back off
If it's really almost new, why don't you take advantage of the warranty?
Apr 17, 2010 | Sanyo VPC-S880 Digital Camera
Camera Kodak C713 does not turn on..even on trying new batteries..It is 1 year old..
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 30, 2009 | Kodak EasyShare C713 Digital Camera
Lens does not retract even with new batteries. How do I remedy this problem?
Here are the steps:
Contact KODAK:
Nov 27, 2009 | Kodak EasyShare C613 Digital Camera
My camera lense won't close even when i turn it off & on. i have tried to turn it off and on the screen only goes on & immediately turns off. the green light in the corner flashes so i know that...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 23, 2009 | Kodak EasyShare V1003 Digital Camera
Canon A710IS Battery Drains Quickly
I have this issue as well, the camera seems to drain the batteries even when it is not on.
Oct 07, 2009 | Canon PowerShot A710 IS Digital Camera
New batteries are not accepted
put batteries in very carefully - not bouncing them in. If you get the 'change the batteries message' then open the battery cover turn the camera a little gently to reposition the batteries and hopefully it should go away. Test your charger too ... is it charging? is it the same thing with non-rechargeable batteries?remember Batteries don't work well when cold this could cause the camera to shutdown. It might also be that the auto shut down setting is too short unless it is shutting down while you are actually shooting.make sure you are using the correct battery type and match.clean the contacts in the battery compactment.hope this helps
Sep 06, 2009 | Canon PowerShot A430 Digital Camera
The camera doesn't start?
did old batteries leak acid?if so it will short contacts that connect batteries try cleaning with rubbing alcohol and qtips and stretch springs a little bit with tweezers!!!!make sure good and dry before installing new batteries also test batteries should bo over 1.5 volts ive had bad new batteries!!!
Jun 28, 2009 | GE A730 Digital Camera
Camera acting weird: turns off a second after turning on...
Hi, I also have one of these cameras which behaved very similarly. The fault cleared when I replaced my rechargeable batteries for new ones or when using new good qaulity branded batteries. When my rechargeable batteries became tired the output was not sufficient enough to fully open the lens. I hope this helps and your
Aug 07, 2006 | Sony Cyber-Shot DSC-P92 Digital Camera
Samsung Digimax 301 Digital Camera Logo
88 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
