Question about Sony DW-Q28A (DW28Q) DVD±RW Dual Layer Burner
A manual for my sony dw-q28a-dvd+rw - Sony DW-Q28A (DW28Q) DVD±RW Dual Layer Burner
cptnkirk4604
  • 39 Answers
SOURCE: Sony DVD RW DW-Q30A Drivers.... and ROM
I would try this website:   http://www.opendrivers.com/categorycompany/15/11558/cd-rom-sony-free-driver-download.html
Posted on Jan 02, 2008
SOURCE: cd not working on my sony dvd+-rw DW-Q58A
I too have the same problem. I've read many of the options and uninstalled drive etc but no success. The DVDs play perfectly, but put in a cd and its bump n grind and nothing happens.
Wondering .... I use the Russian MP3 music sites and burn mp3's to cd, could Sony have a DRM programme that shuts down their drives if you buy from such sites?
Ok Im clutching at straws
Posted on Apr 26, 2008
  • 4 Answers
SOURCE: I have a sony dvd rw dw-q120a. It reads a burned
O **** I GOT THE SAME PROBLEMO
Posted on Apr 28, 2009
  • 439 Answers
SOURCE: SONY DVD+RW DW-Q58A cant even recognize win vista
Does it read other dvds or cds? Have you tried cleaning the lens?
Posted on Jun 21, 2009
VargheseAcer
  • 142 Answers
SOURCE: Hello, I have a Sony DVD RW DW 28A That is
You can try with regedit
If your DVD drive is working fine, then it might be an issue within the OS itself
try these steps
  1. Click Start
    , type regedit in the Start Search box, and then click regedit in the Programs list.
    If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
Posted on Sep 01, 2010
Hi, I have SONY DVD/CD rewritable drive unit, Model No. DW-Q28A. CD or VCD working but DVD not able to work .
The drive is compatible with the following DVD Disc:
WRITE SpeedDVD+R DVD+RW DVD-R DVD-RWDVD+R DL
DVD-R DL
If you are unable to burn using those disc then the burner is defective.
If you want to watch a dvd then you would need to purchase or download a program to watch the DVD movies.
Feb 28, 2011 | Sony Computers & Internet
Lb@aol.comsony dw-q28a will not play getting a code 41. do i need just a up dated driver or a new dvd/cd? thanks any help appreciated. lisa
Hi Liglb,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not play a CD/DVD, chances are your CD/DVD componet needs to be replaced. Good Luck,
    • If this helps resolve your issue, would you please rate the solution.
Dec 29, 2010 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
Hello, I have a Sony DVD RW DW 28A That is rejecting any CD I put in. The DVD is working fine. Can you please help?
try these steps
  1. Click Start
Aug 31, 2010 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
Insert DVD...nothing happens...
You might have to open it up (assuming it's a desktop, not laptop) and make sure the cable is connected inside. The power might be connected, which lets you insert and eject discs, but the IDE (assuming it's IDE) cable also needs to be connected.
Feb 18, 2010 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
August 2005, I purchased this powermac g5. There has been a steady deterioration in the DVD player. Presently, no rented DVDs play. SONY DVD RW DW-Q28A: Firmware Revision: KAS7 Interconnect: ATAPI Burn...
OK. The movie industry strikes again! Your RENTED DVDs are the key.Hollywood made some adjustments to prevent the copying of the movies. So they put software to detect the kind of drives in which the movies are inserted. DVD/RW are capable of copying a movie, so they are disqualified as playing devices. Have it be a normal DVD player you won't be facing any troubles.
Apr 20, 2009 | Apple Power Mac G5 Desktop
Sony dvd rw dw-g120a
I cannot burn my home movies to my dvd drive, my dvd drive is called SONY DVD RW-G120A, it says this device is disabled Code 22, Please help me fix this problems. Thank you
Oct 15, 2008 | Sony DW-G120A DVD RW Dual Layer Burner
My DVD drive reads only Dvd's but doesnot read and CD's?
Two lasers - one for CD one for DVD CD one possibly dirty - so get and run a lazer cleaning disc set and run it or laser burnout -new drive
Jul 04, 2007 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
Sony dvd drive installation
What software and procedure are you using to burn the DVD?
Mar 04, 2007 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
Blank disc not recognized
Sorry no solution, but why burn with mediaplayer/realplayer? you get better results with nero, or other burn dedicated software. Hope you work it out
May 18, 2006 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
Sony DW-Q28A (DW28Q) DVD±RW Dual Layer Burner Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
