Question about Dyna-Glo Heating & Cooling
Dyna Glo Workhorse 210,000 runs fine 5 min then shuts off. Can start right back up but does the same thing.
Just replaced all hoses, filters.
SOURCE: E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
You might have dust in the pilot orfice . If you do the pilot flame curves up and dosen't touch the thermo coupling enough .
Posted on Feb 24, 2008
  • 2550 Answers
SOURCE: Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Posted on Feb 07, 2009
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Posted on Feb 09, 2009
SOURCE: dyna glo workhorse heater
you need to pull top cover off. And bend the igniter in to the spray of fuel and check the gap of the ignighter to 3.5 mm and bingo should work i just bought one and had to do this to it
Posted on May 06, 2009
TheMobilian
  • 8220 Answers
SOURCE: Dyna-Glo model RMC-8000PGH will not stay lit
Your pilot safety is full of dust. Flush it out with shop air or rust buster. Retry
BONUS INFO
Posted on Dec 17, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Fuel shut off switch
Replace the thermostat.
Jan 23, 2014 | Dyna-Glo Heating & Cooling
I have a dyna-glo 120000 rmc-kfa120 heater that won't fire up it tries to when plugged in but then shuts down and light flashes like it is out of fuel and I can't find any owners manuals
I HAVE THE SAME PROBLEM TOOK IT APART AND FOUN A CRACKED HOSE WERE IT CONNECTS TO THE BLOWER CUT ABOUT A 1/1 IN OFF PUT A HOSE CLAP ON IT WORKED FINE THEN STARTED DOING IT AGAIN AFTER A COULPLE OF DAYS TAKE IT ALL APART AGAIN GO THREW IT AGAIN AND PUT IT BACK TOGETHER AND WOKED FINE IT SAYS CHANGE THE FILTER EVERY YEAR ITS NEXT TO THE FOAM FILTER I THINK 4 SCREWS TO GET IT OUT I JUST USED AIR HOSE TO BLOW IT OUT WORKED FINE THEN AGAIN QUIT WORKING SO I DONT HAVE A FIX BUT STILL WORKING ON IT ALSO THE IGNIGHTER SOME HAVE A SPARK PLUG BUT THESE HAVE A 2 PRONG THING 1 SCREW HOLDING IT IN SAND PAPER TO CLEAN THEM TO IM GOING TO TRY A NEW FILTER AN A NEW IGNIGHTER
Dec 13, 2011 | Heating & Cooling
1984 Yamaha Virago xv1000L runs fine for about 5-20 min...then sputters and back fires...pull over to side of road for 5 min, starts right up and is fine...it does not happen all the time...have opened...
have you check your spare tank?? you might be picking up trash from it. it sits on the right hand side under you seat. have you replaced your hoses? that could be another thing to look into, when the get old the start to break down and i have seen the inside of old rubber hoses fall apart. also make sure that you fuel pump is working right.
let me know if you have any other questions about your problem i'll be glad to help
M.Woodring
Jun 01, 2011 | Yamaha V Star 1100 Custom Motorcycles
Have dyna glo forced air kerosene heater, 65000 btu. It's about 10 years old. Not getting fuel to nozzle. Cleaned fuel filter; replaced hoses; cleaned nozzle. air pressure gauge shows pressure OK.
Are the hoses on the fuel nozzle right. Air hose to the front and fuel to the rear. Did you remove the nozzle from the adaptor to check the o-ring? Let me know what you find.
nitensheaterservice@earthlink.net
Niten's Heater Service on Facebook
Jan 13, 2011 | Dyna-Glo Heating & Cooling
BONUS INFO
Dec 17, 2009 | Dyna-Glo RMC-8001SS Heater
Dyna-glo parts
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Feb 03, 2008 | Dyna-Glo (PPH16-LP) Utility Heater
Dyna glo workhorse heater
Jan 18, 2008 | Dyna-Glo (PPH16-LP) Utility Heater
Heating & Cooling Logo
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
