Question about Panasonic DECT 6.0 Expandable Cordless Phone with Digital Answering System
Panasonic KX-TG6071S phone sometimes give 'no line to service' error...i think that's it Fades in and out, and sometimes cuts off all together. Can anyone help?
    Top Expert:
  • Panasonic Master
  • 75,581 Answers
Hello
Check its battery. There is a rechargable battery. If the battery may look like good, it may ahve sufficiant curretnt carrying capacity. If so, this type of fault occur. Repalce the battery. OK.
Posted on Feb 11, 2012
  • phuehner Jan 24, 2013
    It ended up being the Motorola Modem from Time Warner Cable. Go figure. Sure gave us a lot of grief, till it was discovered.
Is there 3 way calling on this model?
[PDF]Operating Instructions - Support - Panasonic
service.us.panasonic.com/OPERMANPDF/KXTG2740S.PDF
PanasonicModel No. KX-TG2740S ... other cordless phone. For Best Performance. 3. For assistance, please call: 1-800-211-PANA(7262) ... •If you use the handset near anothercordless phone's base unit, noise may be heard. .... 2-Way Radio Communication .....&Each mailbox icon will flash if there is at least one new message in the.
Panasonic Product Support - KX-TG2740S
shop.panasonic.com > Get Support
PanasonicObtain product support for Panasonic KX-TG2740S 2-Line 2.4GHz MultiTalk Expandable Cordless Phone System with Digital Answering System.
Jan 21, 2016 | Panasonic KX-TG2740 Cordless Phone
How to change your voicemail on the pansonic kx-T7731
http://service.us.panasonic.com/OPERMANPDF/KXTA824.pdf
That link is to the manual for this phone, pay attention to pages 129 & 155 they talk about VM and customizing your phone.
Apr 17, 2014 | Panasonic KX-T7731 Corded Phone
My KX-TG6511 Phone is in it's cradle but line in use message shows. It's the only one on that line
Check your phone line with a) a new cord between the base and the jack and b) a different phone (I prefer an old cordless phone). If you still get a "line in use" message (alternate errors: fast busy signal or no dial tone), use your test phone at a different jack and determine if the issue persists. If you can, find where your phone service comes in and open the box. If you are lucky and have a fairly new service connection, you'll be able to plug your RJ-11 phone line in and check if there is the problem is at the box. If you can't test at this point, you need to contact your phone company to diagnose if the problem is inside or outside.
If the problem is only with the KX-TG65111 phone, try unplugging the base from the phone line and the cord from the wall jack, disconnecting the base AC power cord (from both sides - phone first) and removing the batteries the handset. After a few minutes, plug in phone line, power cord and batteries and test again. If it still fails, then the phone needs service. These cordless phones are not designed for the home user to service. If the phone is under warranty, contact Panasonic. Otherwise, decide if it is worth having the unit serviced or replacing.
If no phone works at this one jack but does work at another jack, you have a wiring problem at the jack or in the wall to the jack. Try opening up the outlet and check for loose or damaged wires. The jack is either wired directly to screw terminals or punch down terminals. For the screws, it's relatively easy to strip the insulation and retighten the connections. For the punch down style, you will need the appropriate tool. (It's available from many hardware stores in the wiring section.) See http://www.lanshack.com/wire_phone_jack.aspx for a diagram of the pins in the jack wiring.
If none of your inside jacks work, look at the exposed wiring and check for any obvious damage. Otherwise, you'll need to find the problem in the walls. You may want a professional to do the job.
If the problem is outside, your phone company will fix the probem for you for free. If the problem is inside, they'll fix the problem for a fee.
If you have a DSL line and a filter on the line, check and replace that if it is part of your inside wiring.
I hope this helps.
(I've gotten a line in use error with a DSL filter problem after a nearby lightning strike. Since my filter is inside the service box, my telephone company handled the repair.)
Nov 21, 2011 | Panasonic KX TG6511 Cordless Phone
I NEED RESET THE PHONE MODEL KX-TG3280
Generally a reset for this phone would just be "Unplug the power adapter and plug it back in".. but here's the User Manual, just in case that doesn't work.
http://service.us.panasonic.com/OPERMANPDF/KXTG6431-MUL.PDF
Jul 11, 2011 | Panasonic KX-TS3282 Two-line Corded Phone
Recorded messages cant be retrieved from Panasonic answering machine
You've probably done something about the problem by now but just wanted to tell you that the only items that appear on the drop-down apparently are only those the site owner has chosen to list.
I am here often and do not remember seeing nay any to add an unlisted product.
Strange thing to omit.
Aug 23, 2008 | Panasonic KX-TG1033S Cordless Phone
Panasonic DECT 6.0 Expandable Cordless Phone with Digital Answering System Logo
81 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
