I have a wow videoke premium we bought last year, but now the remote control on the mic does not work. The mic is working and has a sound, it's just the control on the mic not working if i want to
Wow videoke premium MTV 2010 edition
SOURCE: Headset Doesn't Work...
Same problem for me, except the headphones wont work with team speak or playing back voice from the sound recorder, I just get a low frequency quiet and very muffled and distoreted sound, Mic works fine with speakers though. :(
Posted on Dec 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Goldstart Microwave Model #MV1526 1000w
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
The service manual can be downloaded here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics. You'll probably have to call them.
Posted on Dec 28, 2008
JulesPCaut
  • 702 Answers
SOURCE: microphone does not record sound after connected to pc
Did you check the Device Manager to make sure the audio drivers are installed and the audio device is working fine?
Apart from that, the sound recording settings in Vista should be set correctly to select the mic as the audio input device (it might be set to "Line in" instead), and to set the recording levels high enough.
Jules
Posted on Jun 08, 2009
freetek
  • 5568 Answers
SOURCE: new crosley CR249-GR "wow and flutter"
I see your message isn't new anymore but Crosley does have a website with warranty and support info:
Crosley Radio
Posted on Aug 15, 2009
gopakumarg43
  • 74383 Answers
SOURCE: I need to program the
Hello
Check with these codes:
0456 [0458 0227]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
OK.
Posted on Jun 19, 2011
My mow videoke premium tkm-370p wo concerto pro 2 mic delay what to do?
HELLO KRIS if your batteries are ok
adjust from the main menu and make some test to check if your voice is not delaying
adjust the tempo from 9 left too slow from 9 to right faster
best regards antonio
Dec 29, 2013 | Audio Players & Recorders
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Feb 03, 2013 | Hampton Bay Dryers
Mic won't work at auxiliary mode
On the remote control, there is a blue "Magic Mic" button. Press on that your mic will turn on in any mode.
Just joking but I've been mad about how bad this LG home theater system is. It can only play extremely limited video files and turn off the mic in AUX mode. So the answer is you really can't do that. Buy a mixer instead.
Jan 19, 2013 | LG Audio Players & Recorders
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
Mic not working properly : I have a iNTEX Headphone with a mic, the mic is not working at all. I've tried recording my voice(which did not work out),In control Panel the default Voice recording device is...
u need to check u r sound setting .plz click on sound icon in taskbar then click on sound property and recording there u can check u r mic if mic not working so srry dude u need to buy a new mic kkkkkkk
Oct 28, 2009 | Logitech Premium Headset
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
HP Premium Sterio Headset ( mic also ) not working.
go to sound settings and then enable the mic by checking off the box.
Mar 28, 2009 | Video Game Consoles & Games
hi Ive got a logitech headset 250 but I cant use that in my laptop and why !??
pleale help me!
see yah bye for now
Nov 13, 2007 | Logitech 250 Headset
Not acknowleging
just make sure that you are hocking up you mic in the right plugs int he back of the computer. just match the colors. you need also to go to the audio panel (it is called volume icon)and check in for mic and make sure that is not muted there. if you use the mic for msn for instance, you need to go to tools, audio and video options and just follow dircetions.good luck
Feb 25, 2007 | Logitech (980240-0403) Microphone
742 people viewed this question
 Grubhead
Grubhead
