Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
Hotpoint side by side has recently bugun making a lot of noise
My 3 yr old side by side refrigerator is now making a loud noise...it sounds like a running engine with a kind of moaning. This just started recently. I thought it was the neighbors using a leaf blower but when it continued on and on for hours, I realized it was the fridge.
Can you suggest anything to make it stop?
  • 65 Answers
Check for frost in the freezer compartment that may suggest a defrost problem which would cause it to run for extended times and make more noise. The other possibility is that if the fan is making a up and down type of noise, it will need a new fan in the freezer section due to a faulty bearing in the motor.
Posted on Jan 27, 2009
I have a 10 yr old Maytag MTB2156GE, it has been making intermittent loud cracking noises for the last week or so, came home today it has stopped working. Can it be fixed? Is it worth fixing?
sounds like the condenser fan motor is bad check in the bottem back of the unit if the fan works if not replacing it is worth on a 10 yr old machine
Sep 02, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Freezer fan makes loud humming sound
sounds like the bearing in the fan motor is gone. need to replace it.. ok
Feb 12, 2011 | Hotpoint HSS25GFP Side by Side...
Every 20 mins or so the fride--a11 yr old
is it shutting off when it makes that clunking noise? if so, thats the compressor making the noise. the motor inside the shell casing, which is suspended on four springs, is banging agasint the shell casing because one of those springs has stretched or broken. You need to replace compressor. if its been happening for a while, i would start looking for a new model. if its more recent, and not very loud, you haver more time, but in either case, it could just cease up at any time. to hgave your compressor replaced, and unless your an HVAC tech you should most assuredly NOT do it yourself, its quite expensive, at or near the cost of buying a new one.
Feb 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer fan making loud noises!!!
Hi: When the circulating fan between the freezer and fresh food compartment goes it will make a racket. like a bird chirping or a flying saucer. It's toast at this point. As repairs go it's not expensive (that's grading on a scale.) If you are handy the fan will be about $40.00. It's mounted behind the plate in back of the freezer. Get a parts list and diagram for it it will show you where it goes. Sears parts is a good place to go for that on line. I hope this helps, Jeff
May 31, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint side by side refrige problem
Sounds like the gear jammed , replace the ice maker for a fix.
Apr 10, 2009 | Hotpoint HSS25GFP Side by Side...
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Whirpool Refrigerator Making Loud Noise
I have the same problem. 3 years old fridge. Under warranty?
Aug 08, 2008 | Whirlpool GC5SHEXNS Side by Side...
Fridge makes loud moaning sound
It is the control board. There is a recall on certain models and serial #'s that will cover the parts, but not all are covered. do a google search for hotpoint or GE howling noise. you will find out all the info you need.
Mar 14, 2008 | Refrigerators
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
277 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
