Question about Jensen Fluke LAN CableMeter 620 (317-620) Network Testing Device
Sel test faild
When I start my Fluke Lan 620 , it beep 3 times and on the panel ther's ( self-test ? NV). What I must do?
  • Anonymous Mar 12, 2009
    self-test? nv please help!
Google com
Apple has a variety of 'beeps' (sound) and 'blinks' (lights) for both computers and monitors. Your 3 beeps (wild guessing here) could be as noted in this link below ... which will also steer you in the right direction. Note too, that blinking lights - can have a pattern (3 blinks: short-short-long, for example). These also have specific diagnostic meanings and you might make a note before searching.
Link to some ref on blinks and beeps is here (a paste follows this note too):
https://discussions.apple.com/thread/4357348?tstart=0
G5 mac reference - PASTED DIRECTLY FROM THE APPLE COMMUNITY SUPPORT PAGE AT THE LINK ABOVE:
Limnos Sep 26, 2012 9:00 AM
in response to Kort ' This helped me
For future reference:
Power-On Self-Test Beep Definition - Part 1 - http://support.apple.com/kb/TA43884
Power On Self-Test Beep Definition - Part 2 - http://www.info.apple.com/kbnum/n58442
The power on self-test resides in the ROM of the computer. This test runs whenever the computer is turned on after being fully shut down (the power-on self-test does not run if the computer is only restarted).
If a fault is detected during the test, you will not hear a normal startup chime. Instead, the system will beep as explained below. If you experience one of these beeps, you may call your Apple Authorized Service Provider for additional troubleshooting assistance.
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
In addition to the beeps, on some computers the power LED will flash a corresponding number of times plus one. The LED will repeat the sequence after approximately a 5-second pause. The tones are only played once.
You can also run Apple Hardware test from your original installer disc. Sometimes with RAM it is just easier to pull units and test them individually.
Aug 19, 2014 | Apple iMac Computers & Internet
Malfunction
Hi - You can download the manual from the link underlined in blue below:
CDX-R3300
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 03, 2008 | Sony CDX-R3300 CD Player
Beeping mac
Try resetting pram or nv ram by holding down apple and option on left of space bar and the letters p and r and keep them depressed before the first chime and until after the third chime.
These beeps are a sign of self test failure. Might get lucky and be able to start in safe mode by holding down s key when you boot it up.
Feb 20, 2014 | Apple Computers & Internet
6 beeps what dose it means
Dell beep codes:
If your computer beeps during start-up:
Run Dell Diagnostics to identify a more serious cause.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Contact Dell for technical assistance.
Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM read/write failure 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer failure 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3 Video Memory test failure 1-3-1 through 2-4-4 Memory not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller test failure 3-3-1 NVRAM power loss 3-3-2 Invalid NVRAM configuration 3-3-4 Video Memory test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No timer tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math-coprocessor test failure 4-4-4 Cache test failure
Aug 12, 2013 | Dell Gx620 Gx 620 Sff P4 Ht 2.8ghz 1gb...
Display problem, CPU Fan starts but no Power on self test begin. Pls help
The computer power-on self-test (POST) tests the computer to make sure it meets the necessary system requirements and that all hardware is working properly before starting the remainder of the boot process. If the computer passes the POST the computer will have a single beep (with some computer BIOS manufacturers it may beep twice) as the computer starts and the computer will continue to start normally. However, if the computer fails the POST, the computer will either not beep at all or will generate a beep code, which tells the user the source of the problem. Once the problem is located, simply replace the defective part.
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep CodeDescriptions1 shortDRAM refresh failure2 shortParity circuit failure3 shortBase 64K RAM failure4 shortSystem timer failure5 shortProcess failure6 shortKeyboard controller Gate A20 error7 shortVirtual mode exception error8 shortDisplay memory Read/Write test failure9 shortROM BIOS checksum failure10 shortCMOS shutdown Read/Write error11 shortCache Memory error1 long, 3 shortConventional/Extended memory failure1 long, 8 shortDisplay/Retrace test failed
Jul 27, 2011 | Gigabyte Computers & Internet
HI, I have two 3com patch panels 3C17302 Superstack 3 Switch 4250T, connected to a switch panel. One of the patch panels does not work e.g. the connected pc's are not able to have Lan connection. Only...
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Nov 22, 2017 | 3Com Computers & Internet
Fluke 1651portable multifunction tester is displays Err 1
Error 1 is an indication that the self test has failed. This will require repair at an authorized Fluke service center. There is an internal problem with the meter. The only thing that you can try is to replace the internal battery. Should the battery be defective, the internal testing can be effected. I have only seen this occur once, but it is worth the attempt. Should a new battery not fix the problem, return the meter to Fluke for repair.
Dan
Apr 15, 2010 | Fluke Networks Fluke T+PRO Electrical...
I have a MPC NetFrame 620 server . It bagan to
replace with a new card. The beeps are indicitive 0f failed hardware 2 beep 2 beeps = video card series of 3 beeps keyboard ,malfunction etc etc so whichever card now gives you one long beep you had better start there.....
Jul 28, 2009 | Computers & Internet
Screen won't appear upon start up and I get 3 beeps but no screen
3 beeps POST code (power on self test) means RAM problem.
Reseat the RAM module/s and boot up your computer.
If you have two RAM modules, remove them both and insert one at a time to test them, to determine which module is faulty.
If it still doesn't work then replace the RAM module/s
Apr 02, 2009 | Everex StepNote NC1500 Notebook
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Jensen Fluke LAN CableMeter 620 (317-620) Network Testing Device Logo
53 people viewed this question
Top Jensen Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Jensen Computer and Internet Expert? Answer questions, earn points and help others
