Goodman furnice lights runs until eletronic igniter powers down and shuts off
  • Heating & Co... Master
  • 3,253 Answers
Try cleaning the flame sencor or its the presure switch which is faulty
Posted on Feb 11, 2012
Therinnaiguy
  • 1420 Answers
SOURCE: new 95% goodman keeps giving Code 1
Not having a model number to help you with, I can only give you generic info. Typically a flashing 1 represents that the furnace has exceeded its allowed attempts to start. Not much help. If I can suggest removing the access panel on the furnace and tape down the door safety switch. That being done, have a helper turn up the thermostat and you get your head inside the furnace cabinet and document what it does. It should first blink on the LED indicating a call for heat. Next the inducer blower should start up (the small blower hooked to the exhaust pipe). Next you may see an orange glow where the burner is. There should be a small clear port where you can watch this. Next some clicking should be heard from the gas valve. Then the orange glow should turn to a blue flame. This flame should travel all the way right and left igniting all the burners. Then it should stay on until the call for heat is satisfied.
After doing this and with your model number, get back to us and we may be able to pin-point your issue.
Posted on Dec 24, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: goodman modle gmp100-3revb heater ignites and then shuts off.
If you are getting ignition but it does not stay on long, check for a bad ground off of the circuit board to the chassis cabinet. Look at the flame sensor and the connection on the circuit board. Is the plug making contact to the board or is there a bent tab? Is the flame spreading from one side of the burners to the others very quickly or slow? If quickly, it has to be either the sensor or the control board. If slowly, clean the burners and the flame spreader.
Posted on Jan 02, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: goodman gmp125-5 burners ignite, then shut off after about 5 sec
One of two problems are happening here, your flame sensor is bad, your thermo pile or thermo couple is bad, or last is that the cap on the flue is blocking the exhaust from escaping
Posted on Feb 09, 2009
  • 189 Answers
SOURCE: Goodman Model GMNT100-4 Auto Power Down and Up until Temp.
Keep in mind all furnaces and circuit boards are not the same. Look on the back of the door to the blower compartment. You should find the list of diagnostic codes. Look up four blinks it should narrow down the problem. Although from the discription you gave it sounds lie the high limit control. When a high limit appears to be acting up it DOES NOT mean that the high limit needs replaced. The high limit just may be doing its job. This means that the furnace is overheating. Check your filters. Are all of your registers open? Is your blower set on the right speed? Is your blower going bad? Is the blower motor capacitor bad? Is your evaporator coil restricted? Just changing a high limit switch does not always solve the original problem!
Good luck....
Posted on Apr 03, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GDT070 furnace pressure swich problem.
Inspect both the intake and exhaust pipes for blockage or debris. Inspect the small tubes that go from your combustion fan to the pressure switch and the tube that goes from the fan to the condensate drain. They all should be clean and dry. Inspect the combustion fan to see if it spins without it scraping on the housing or it may be filled with water or debris. Last, check the air filter and clean or replace.
Posted on Oct 11, 2009
Working on furnace. igniter not working even after replacing.
Check flame sensor , check hoses to pressure switch not split etc
Oct 24, 2015 | Goodman Heating & Cooling
My Goodman ARUF182416 does not stop running. I have disconnected the thermostat and the blower and heat element stay running until turning off via circuit breaker.
From what I can gather it seems like a power source error (red wires attached to the transformer) is allowing it to keep running. Another possibility is it could be your speed tap. These are my speculations about what is occurring.
Dec 11, 2014 | Goodman Manufacturing Goodman ARUF182416...
Pilot gos out when burner shuts down wall furnice
Usually thats a sighn of a bad thermocouple,thats the copper tube that goes from the gas valve to the actual pilot assembly it senses that the pilot is burning and allows the main burner to light. If there is no pilot lit the bur will not light. Its there to keep you home from exploding from a release of gas with no pilot. The good thing is that most ofthem are universal and most water heaters use the same one. And you can buy one for a water heater at lowes or home depot for about ten bucks. If you get one thats longer than the origional thats ok because you can just coil it in a circle just be carefull and dont kink the tube,if you do kink it you must get another one. even if you straighten it.
It wont work. Hope that gets you going and warm.
Jan 12, 2013 | Vanguard International Blue Flame - Medium...
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
Our furnace keeps shutting down soon after burner ignites inducer motor stays running wont heat until reset switch behind inducer motor is pushed
Sometimes a "Flame Sensor" gets carboned up and does not detect that the furnace has ignited, so it shuts down the fuel source. Might try cleaning that if so equipped.
Dec 05, 2010 | Goodman GPG152407041 15 SEER Packaged...
Goodman gmt or gmth not igniting burner. We have
First pull wires off the pressure switch and put a jumper wire in, if it lights bad switch. If it doesn't light, bad ignitor.
Jan 04, 2010 | Goodman GMS90703BXA Heater
Good luck....
Apr 01, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
