Question about Garland Kitchen Ranges
My Garland Airdeck G56PB pizza oven will not keep temperature. And now I can't get a spark to the ignigion module. I replaced the thermostat, the transformer and the ignition module (3 times)? An
Has been acting up for months. replaced ignition module 3 times. works for a while, then won't keep temp. turn off and on again and it will work for a while. now can't get it to fire up. replaced the ignition module again, but didn't help. still no ignition.
  • 15 Answers
SOURCE: garland stove pilot light problem, again but different
I'm not familiar with Garlands. When I run into a similar problem with other stoves of that vintage (Wedgewoods, etc.) I trace the pilot lines piece by piece, from the manifold to the pilot burner, if necessary opening a connection or two to see where I'm getting gas and where I'm not.
Is there a needle valve for adjusting the pilot flame? Is there gas getting all the way to the pilot burner? When it's the pilot burner itself that's the problem, I take it apart, brush/blow/shake out the crud, and run a small drill (#79 or so) through the orifice.
Posted on Dec 19, 2007
  • 125 Answers
SOURCE: We want to refurbish the old Garland stove in our church kitchen.
Hi, I am sure you can still get the thermostat replaced, however, it is unlikely anyone will service the unit without oven safeties, for insurance/liability issues. You may be able to get it updated with these devices, but I would bet that you could find a newer used unit that is in fair to good shape for the same or a little bit more money. You can contact Garland range at www.garland-group.com, call 1 800 424 2411, or look in your phone book in "restaurant equipment repair" for a company to advise you, and "restaurant equipment sales" for new/used equipment. Check on ebay for approximate prices if you are curious. Hope that helps, and thank you.
Posted on Jan 04, 2009
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
SOURCE: Roper Gas Range
F1 Error
My Roper gas range is sounding an alarm call with number F1 flashing. Can anyone reveal what the code means before I call service? Thanks!!
Posted on Jul 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: Hotpoint gas oven won't keep its temperature. I
The temperature sensor in the oven needs replacing. It is located in the back wall of the oven. About 3 inches long,metal and about the size of a thin pencil.
Posted on Nov 22, 2009
Need parts for a Garland pizza oven
heritage food service,parts town,whaley food services I would start with these
Apr 22, 2012 | Garland E56PT/B Air Deck Pizza Double Deck...
Pro Series PS3240 pizza oven , made by PESI. refurbished Middleby.
Call Shimmmer LLC, at 602-447-0304, we specialize in pizza equipment. And deal very closely with PESI ovens. ;)
Dec 06, 2011 | Kitchen Appliances - Others
My lincoln impinger pizza oven keeps showing LLL on temp reader after reaching its temperature,then the temperature keeps rising until it shuts off.
This error LLL on the display screen is as a result that the temparature controller is faulty or the the temparature probe is kaput
Apr 29, 2011 | Lincoln 1132000U - Impringer II Express...
I have a commercial garland air deck gas oven model G56PB its not staying heated to the set temp. it will heat up to the set temp. then five minutes later the tempreture will drop and will not heat up to...
I have seen Garland's have issues with the pilot light. see if you can watch the cycle.It may takes several minutes. I have seen where the pilot actually lifts off the pilot assembly and go out and cause oven to fail. Turning off and on resets the failure and sometimes it will light. Start there and be patient.
May 11, 2017 | Garland Ovens
Ovens conveyor belt is working, but the heat and air are not working
A conveyor belt oven would make things so much easier for the staff of a pizza restaurant . Is it possible to get a wood fired conveyor belt oven? If not .... could I build one?
http://www.cookbookclub.net/breakfast/breakfast-home.php
Apr 18, 2010 | Lincoln Conveyor Oven - 1130-000-A
Temperature Control Knob Replace
If there is no visible screw hole the knob should just pull off. If it is an oven thermostat, they can sometimes be hard to pull off.
Mar 23, 2009 | Garland H283 Gas Kitchen Range
Garland oven does not work
Hi, it is hard to tell for sure, but it sounds like your safety device, the component that keeps the pilot lit, may have failed, allowing gas to the pilot, but not letting gas through to the burner. See your manual on/off valve lets gas to the thermostat, then through the thermostat down to the safety, because you wouldn't want gas to get past there if there is no pilot, and now that part is stuck open, but the rest of the part is not engaged to open and let gas continue to the burner. There is an easy way to tell, under the bottom panel, is a part with a red button ( the safety ) and connected to it is a copper looking tube, or the thermocouple, it can be disconnected by unscrewing it from the safety with a wrench, if the pilot goes out, your safety is mostly working, if not, it is bad, and needs replacement. Let me know, hope that help, and thank you.
Jan 05, 2009 | Garland H283 Gas Kitchen Range
May 05, 2008 | Garland H283 Gas Kitchen Range
Kitchen Ranges Logo
81 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
