Question about SanDisk Electronics - Others
Sandisk Blade "there is no media the specified device"
I was downloading i file on my usb and suddenly i not recognized and i cant formatted and download many programs to format it but it give me this "there is no media the specified device" please help me .
bob_computer
  • 3153 Answers
SOURCE: SanDisk Usb Flash 8GB unable to format
TRY SOME OF THESE STEPS BEFORE YOU THROW IT
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 17, 2009
ashishd19
  • 35 Answers
SOURCE: Can't format my sandisk micro cruzer 16gb flash drive
Try this --
Download the HP disc format tool using this link--
http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
After downloading the file you need to install this.
After installation,launch the software, and select the Flash Drive Letter and try formatting.
If this does'nt work,plz let me know and I'll give you one more alternative.
Posted on Nov 15, 2008
SOURCE: PEN DRIVE SHOWING 0 FREE SPACE AND ZERO USED SPACE
Hi
Just go to My Computer.right click on Manage.Then click on Disk Management.In the bottom tab you can see your pendrive.click on it get a new partiotion using NTFS.
Posted on Jan 06, 2009
  • 70 Answers
SOURCE: i cannot format my transcend usb pendrive...
format using dos
start
all programs
run
type cmd
if you drive is g then type
format g:
if your drive is f then type
format f:
for details visit me at gautam.nischal@yahoo.com
Posted on Apr 15, 2009
  • 273 Answers
SOURCE: formatted a 2GB sandisk card in my camera. Lost
If you have an sd slot in your computer you can plug the card into sd slot start/computer/right click removable hard drive disk for sd card format
Posted on Mar 01, 2010
Cannot find specified file
okay, problem isn't in ur pendrive problem in ur computer, some kind of viruses attack only removable drives, and user didn't find viruses in computer and also antivirus, you should download microsoft security essential here,--- http://windows.microsoft.com/en-IN/windows/security-essentials-download , and update this software insert ur pendrive and start virus scanning as a whole computer including ur pendrive ur problem will surely solve
Mar 08, 2014 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Usb device not reconised
This message is usually shown when the flash drive is burnt. Try to see if it presents the same message in different computers. if it does, unfortunately it is damaged beyond repair.
If it is recognized as a drive, but it is asked to format the flash drive, try formatting it and see if you can copy and delete files from it. If you cannot, it is really burnt.
Hope you may find this information helpful!
Regards,
Miguel L. Martins
Nov 08, 2013 | SanDisk Cruzer Blade Usb Flash Drive 8 Gb...
Sandisk cruzer 16gb, Macformat, tv won't recognize
Dowload codec Klite pack, via Google, and open the files with that media player, the tv should then pick it up, seeing as its a multi codec reader program, Hope it helps
Jan 16, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Cant format mp4 philips sa312455
i can solve your problem..its an easy way.since you have specified that your computer doesnt recognise it, you have to generate the system file. you can do this by either record a voice and save the file in your device. then connect your device to your computer. it will detect it and you can format and upgrade . the only thing is somehow you have to record the voice in your device.
May 27, 2009 | Philips GoGear SA3245/37 Digital Media...
Computer willnot recognize sansa clip, Begins coonection and then ends imediately after. I have downloaded wmp 11 and i run xp, help?
ok, look turn your device on and select settings, next you want to find usb mode (wording may vary). select this option and change this setting to msc, i have a 2 gig clip and this seemed to work......if this doesnt work try the mpt setting under the same "usb mode" option.....also when putting songs on your device, make sure the files are in wma format(windows media audio) to do this , see the songs properties, ussually done with a right click on the songs shorcut or logo.....if the file is in mp3 format, open the song in windows media player and open the library tab, highlight what you want to put on your device right click and select send to .....then select audio converter, convert the files then send them to your clip.
Mar 30, 2009 | SanDisk Sansa Clip MP3 Player
My computer cant open the file in my e250
1. Plug the sansa into your PC. If Windows does not recognize the clip, unplug it, turn it off, and then put the clip in "hold" mode by placing the on/off switch into the hold position. Hold down the middle button on the Clip while you plug the clip back into your PC. It should recognize it.
2. From "My Computer", find the sansa icon and choose format. Note: this will delete all your music files on the device...
3. Download the firmware updater for the sansa
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
4. Follow the instructions to update your firmware.
5. If you need additional assistance try calling Sandisk's tech support:
1-866-SANDISK (726-3475)
7 days a week:
4am. - 10pm. Pacific Standard Time
7am - 1am Eastern Standard Time
I hope that helps
Please rate accordingly
Thank you
Computerrep
Nov 03, 2008 | SanDisk Sansa e250 MP3 Player
Formatting issue
Does the device show connected? If so check the device manager for any red or yellow errors. If there are errors, right click on the device and select un-install. Disconnect the device from the computer, wait a few seconds and reconnect. The device should re-install the drivers and device should be recognized. Best of Luck.
Sep 15, 2007 | SanDisk Sansa m240 MP3 Player
Sansa m230 cannot see previously installed music files now that WMP11 is installed
I had the same problem on my m230. The final solution that worked for me was to disconnect then go into settings;usb and set it to MSC. Once I re-connected I could see everything.
Feb 06, 2007 | SanDisk Sansa m230 MP3 Player
Electronics - Others Logo
2,762 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
