Question about Milwaukee Tool 10 Amp Sawzall Plus with Quick - Lok Cord
Sawzall quit working
Was using sawzall and it would not turn back on. Thought maybe the brushes broke or wore out but they look fine. Could the twist lock power cord have a short? I tried to test it with a voltmeter but don't get a constant voltage. How can I test to see if the cord, trigger or brushes are bad?
Thanks for any suggestions.
-Randy.
    Sergeant:
  • 314 Answers
With an ohm meter check the pins where the cord plugs in. Pull the trigger and check for a reading. If that's ok, then do the same with the power cord for a reading from the plug to the terminals on the other end. My guess is that you will need a new cord. Do Not Patch a power cord!! Frankster016
Posted on Oct 23, 2008
  • 2,176 Answers
You didn't specify if it was a twist lock cord or not. If it is maybe one of the pins pulled out of the locking mech, you could still get a reading but it will not lock into the pin housing on the tool. The switches in these tools have a remote electronic which you cannot check with a volt ohms meter. One last thing look at the spade terminal on the brush holder sometimes they back out giving you a fit.
Posted on Dec 09, 2008
My milwaukee sawzall won't start. It click'S when I pull the trigger,and led light above the blade starts to pulse in increments of three flashes. Any ideas on what would cause this??
try to switch a full battery look the carbon brushes try to turn on the motor to look its has no point with to heavy resist maybe a defect in the mechanism or electrical problem armature carbon brushes
Jan 06, 2017 | Milwaukee Saws
My milwaukee 6514-20 hatchet sawzall just quit, thout it was switch but that did not work! Is there a way to troubleshoot the armature? Sonny - 541-441-7900 ...
Sonny, can't respond directly but yes there is a way. remove handle half and first check the brushes for their condition and resistance across the commutator of the armature, slowly rotate the armature and keep checking. If you get a reading close on each contact the armature should be fine. check the condition of the battery also. and while checking check from the switch/battery contacts to the brush leads for an open. Let me know if you need more assistance.
Apr 17, 2011 | Milwaukee Tool Milwaukee 6514 20 18V...
My van won't start. The serpintine belt broke and I replaced it. It is installed correctly but the engine won't turn over. It trys to start but won't. Any suggestions?
How long did you run the engine after the belt broke? Does it sound like dead battery? The alternator quit when the belt broke, the car will run for maybe 20 mins without it, I would say you wore down the battery, get it charged back up and see what happens. There is nothing else that will make your car not start that is attached to the serpentine belt.
Jun 11, 2010 | 2000 Oldsmobile Silhouette
Our belt broke and now i can't find out where it should go back! The second one broke too so I thought that maybe I was putting it in the wrong location>
check the brush make sure the ends spin freely if so put the belt on spin the brush with your hands 3 or 4 times around the belt will seat its self
Dec 14, 2009 | Vacuums
Super Sawzall 6527 just stopped working. I did an
could be a couple things, unplug tool and look at the pins on both the cord and the pin housing to make sure none pushed back, next remove handle half and remote electronic and look for a loose flag terminal at the brush holder, look for loose wires on the switch, (give a gentle tug) and remove the brushes and look for unusual wear patterns and possibly a burnt brush spring. Let me know if you need more help.
Nov 22, 2009 | Milwaukee Tool Saws
Sawzall goes dead when horizontal top right
could be a break in the cord or a loose terminal at the brush holder. If you are mechanically inclined get back with me and I will instruct how to find. You will need the exact model number. If this is a quick lock cord as listed unplug and look at the terminals to make sure one not pushed away from tool and condition of the plug in handles. Let me know
Sep 06, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Yesterday, while I was brushing my teech I broke
go ask your dactor if he can do anthing
Jul 09, 2009 | Health & Beauty
Sawzall wont turn
OK you lost me on the second one. All you have to do is keep the brush tube from moving (UNPLUG TOOL) and using the commutator pry up/push up on the spade terminal to reinsert it, you can also solder these direct to the tube using something like TinsTighter first. I don't understand about the brush and adjustment part. There is none. If this helped would you please rate the information. I still think on the second one a new set of brushes and the above might cure your problem.
Mar 17, 2009 | Milwaukee Saws
Roller brush doesn't turn
Sounds like the belt is maybe slipping did it brake the new belt as well?
Mar 10, 2009 | Vacuums
Saw quit
OK there are quite a few things to look for. It seems that you are comfortable with some disassembly so lets go further. I dont know what model you have but it still might have a broken wire or the pins pulled out of the plug end. Look at that first. If you have power thru the switch I would next check the field and while there look at the "flag" terminals that go to the brush tubes, they had a habit of coming loose and stopping the tool. If this is the case you can remove the brushes and after pushing them back solder them to the brass tubes. Lastly roll the armature by hand and look for any serious discoloration or differences on the commutator. Let me know if I can help more.
Jan 12, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Milwaukee Tool 10 Amp Sawzall Plus with Quick - Lok Cord Logo
463 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Dave
Level 1 Expert
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
