Question about Coby TFTV3227 32 in. LCD TV
Tv and converter on but no sound and no picture
Tv and converter on with no picture or no sound
I have an 15" Curtis tv model number is LCD 1575! do I need a converter box? If not how can I make it work there is no picture or sound ??
A converter box for what precisely? And how long have you had this tv? No picture or sound may be a broken TV. It could also be that you have the wrong input source selected. What are some other odd symptoms, other that no picture or sound. What exactly are you trying to do?
Jan 31, 2013 | Televison & Video
Trying to hook up digital converter box but cant get reception
This seems related to the TUNER and the IF section as the sound- audio and picture- Y signal does not process with the correct alignment.
Dec 06, 2011 | Audiovox VE727 7 in. Under Cabinet TV
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
Our tv doesn't have sound or picture
You need a Digital to Analog converter box as your TV is analog, and all broadcasts, since Last June 12 are Digital.
Apr 16, 2010 | Sylvania 6520FDE 20 in. TV/DVD Combo
My insignia lcd37 is hooking the comcast modem and works at times. Other times the sound is on, but the picture is blank. Is it worth fixing or just start over.
Okay you TV is hooked to a comcast modem? or do you mean My tv is hooked to the comcast converter box? A no picture but sound you want to first check you cables also try hooking up a dvd to the tv and see if that picture comes on if not and you got no pic and sound this would mean the backlight on this tv is dead or you got a bad inverter not converter, inverter inside the tv. Meaning it needs the repairshop but try and hook up a dvd to it and see if you got picture if so you cable box might be the issue call comcast!
Thanks and please leave valuable feeback and ratings today!
Dec 11, 2009 | Insignia 37" LCD Flat-Panel HDTV
Quasar combo tv/vcr, blue screen and no sound, I can play my dvd sound and picture, just no tv...help
Thank you, but I have resolved the problem, I read some complaints that sound close and tried plugging in the input jacks from the tv to the converter box and the picture and sound came on...oh what a relief and thankful
Mar 24, 2009 | Quasar SP-2723 27" TV
Was watching tv( Toshiba Regza)and the screen went blank.
I have the same television and ocasionally the sound shuts-off, but I still have a picture.
What type of cable system do you have? What kind of converter box? I am trying to find out if it is the TV or converter box. I change the channel a couple of times and the sound usually comes back.
Feb 17, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Toshiba 36AFX61
Just Connect signal to tv and run autoprogram. Or use video input jacks from converter to tv ( yellow,white and red video in ) and select tv/video on tv pannel front ( don't need remote control) I hope this work for you.
May 11, 2008 | Toshiba 36AFX61 36" TV
Coby TFTV3227 32 in. LCD TV Logo
66 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
