Question about Asko Dishwashers
No power showing on machine and water not draining for Asko D1606.
Previously repaired 18mths ago for same problem with parts replaced and cost of $615. Parts replaced Inlet valve sinle 230V formerly 8057507, Hose Clip RFZ, Seal, Nitrile, Ball catch, Circ.Pump kit DW95 and Hose clip Oetiker. Has the machine had it?
5 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: New World DW60 dishwasher not
I f you have warranty on this please call them, you have a defective D/W.Unless there is no charge for repairs ,don't spend a dollar on what is going to be a on going problem ahead.To explain how to fix this is what the manufacturer should have done in the factory and not made 1 dollar off of this defective D/W until it proved this to be ready .What has happened to Quality Control ? Does it no longer matter ? Very sorry ,you should seek a refund ASAP.
Posted on Jun 23, 2008
  • 159 Answers
SOURCE: Asko D3530 water inlet fault code, water valve is
All im going to say is i think you have a faulty inlet valve.the water is probably only trickling into the machine & taking forever to fill,the computer board has probably picked up that the washer is taking to long to fill & has thrown up a fault code relating to the fill or inlet valve.Also sometimes if the filters in the bottom are clogged the water cant get to the wash motor & the motor cant load up with water.The motor runs without load on it & the computer board interprets this as slow fill or inlet valve problem.
Posted on May 28, 2010
  • 414 Answers
SOURCE: An earth leakage occurs on an Asko D1606 about a
That would be the water heater, but if the unit is taking out the RCB it could also be that the earth leakage allowance on your consumer unit is too low or there is a problem with the mains cable suppressor (if the unit has one).
All the best
Posted on Aug 15, 2010
kel1guy2002
  • 3740 Answers
SOURCE: GE Potscrubber Dishwasher Model GSD
Hi and welcome to FixYa, I am Kelly.
There is and internal float switch that controls power to the inlet water valve. If the float is sensing that the unit is full of water it will go through all portions of the cycle but.... will not have any water in it at all.
Take a look at this diagram and check items 302 through 308:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=209408&diagram_id=20816425#d20816425
The float should move up and down around 1/2 inch. I believe your float is stuck in the UP position. This is usually caused by food particulate on the stem (Item 306). Clean it up and it should work. You can gently push the stem up and down from under the unit and you should hear the micro-switch click as you raise and lower the stem. No click = bad micro-switch / no power to the inlet water valve. You can briefly jumper across the micro-switch to see if you get water flow during fill cycle. Just be aware of the dangers of working on live circuits.
Thanks for choosing FixYa,
Kelly
Posted on Feb 16, 2011
Asko D1606 won't fill, and sounds like pump is running
This means the unit has taken on water to the base pan and will not allow you to do anything until the water is removed. Once the water is gone you will need to locate or fine why water reached the base pan to correct this problem. Most common reasons, too much subs, leaking hose, leaking drain hose behind the unit and traveled back into the unit. Without seeing the unit the cause would just be a guess. I hope this helps. If you unplug the unit allow 2-3 days to dry out, this may allow you to run the unit and locate the original cause of your leak. good luck
Mar 26, 2016 | Asko Dishwashers
Model W0611. How do I replace the door seal?
Hi John, the following YouTube video link may help, if this is not your model there is a further link in the video showing more ASKO machines, both links are shown below.
Trust this helps, regards Alan.
Washer Door Seal Replacement Asko Washing Machine Repair Part 8081128
Washing Machine Repair Help
Jun 08, 2015 | Asko Washing Machines
D1606 not draining
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
May 02, 2011 | Asko Dishwashers
Need to replace solenoid valve on asko w6oo .Water no longer entering machine. How do I replace the valve or get repair manuel ?
Quite easy, Valve is removed by loosening two scews/or twisting valve off, remove the 2 hoses too...Remove wiring then refit..Turn off water 1st and electrics....Good luck, parts cost about £10
Nov 02, 2009 | Whirlpool AWM5104/1 Front Load Washer
Cabrio drains water onto floor.
I took the back cover off of the machine and found that the drain pump had a hole in it. The hole was caused by a coin that had made it's way down to the drain pump. The replacement pump cost $90.00 and was very easy to put in. If you google the words cabrio tear down you will come across a web site that has a video that shows you how to take the pump out. I have not had any leaks since. Keep the coins out of the washer, remeber to check your pockets to avoid paying out cash.
Jun 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Asko D1716 dishwasher problem
I also have an Asko D1716 dishwasher. The water stopped flowing. I replaced the water inlet valve and I have another problem, but the replacement of the fill valve is now letting in water. You can call Asko at 1-800-898-1879 to order the parts. If you order from Asko, I'm told you have some warranty on the parts. Anyway, the screws take a star drive and there is a front plate and back plate you will need to remove. There are approx. 4 screws on the front and 4 screws on the back. Just remember to unplug it before starting any work. The fill valve is in front of the machine. There are 2 screws holding it in place from the front. You will need to remove it out the back though to replace it since the fill tube to the tub is short and it wont allow you to pull it out the front. The repair is really easy once you get started.
Hope this helps,
Sargeantfod
Jun 11, 2008 | Asko D1716 Built-in Dishwasher
ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Dishwashers Logo
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
