Question about Baby Care
My Summer Infant babyTouch Color Video Monitor has no signal
The monitor reads no signal
  • Matt Feb 11, 2012
    I have read and followed the directions in the manual but instead of the camera blinking when holding the code button on the back, it just kind of flickers. The monitor attempts to add the camera but just returns to the home screen and continues to read, NO SIGNAL.
  • 10 Answers
SOURCE: My monitor ( imonitor Digital
Try rebooting the system, if it is within the warranty I would contact Graco or the store you purchased it in!
Posted on Feb 28, 2011
  • 1587 Answers
SOURCE: I have a Summer Infant Monitor. Model 2010. The
I was unable to find any direct information on a Model 2010 Infant Monitor. The picture shown by Fixya is of an LCD handheld monitor.
If I understand the problem correctly, you are seeing a picture that is only 1/2" wide in the center of a 4" or 5" CRT (similar to one of the three CRT models presently shown on the Summer Infant site. You did not state whether it is full height, or if it is a complete picture rather than simply truncated at the sides.
If it is a complete full-height picture, but squashed into a 1/2" vertical stripe, the vertical deflection is OK but you have a problem with the horizontal deflection. Since you have more or less full brightness (you did not mention any problems with that), the horizontal oscillator is working and producing the proper 2nd anode voltage through the flyback transformer. In many small black and white CRT monitors the horizontal deflection current is coupled through a non-polarized electrolytic capacitor. If this is going bad, it will produce this symptom.
If the entire picture is undersized and dim, you may have a power supply problem - if it is also erratic and you hear snapping sounds, it's could be the flyback transformer. If the picture goes edge-to-edge horizontally, but is squashed into a 1/2" high strip, you have a coupling problem in the vertical deflection circuit. A non-functional vertical oscillator will give you a single line across the center. A malfunctioning vertical oscillator will give you a rolling image.
Have you checked the safety recall information on these infant monitors? The two primary issues are keeping the cables away from the baby, and battery rupture problems on certain models.
Posted on May 03, 2011
SOURCE: My brand new summer infant slim and secure baby
Keeping the LED monitor portion on the entire time sucks the battery pretty quickly on mine. It has an automatic shut off button but if you're like me, you probably check it constantly. I found that when I'm not turning on the LED portion and also turning it off when he's awake and with me, it keeps the charge MUCH better.
Posted on Aug 19, 2010
edorduno
SOURCE: my summer best view handheld video monitor says
Have you tried pressing the pairing button at the back of the camera unit and press the scroll button at the center of the receiveing monitor at the same time as suggested by the manual? I had the same problem, followed the manual instructions and solved it. (Greetings from Mexicali, M
Posted on Sep 25, 2010
SOURCE: My Summer Infant Best View
im having the some problem, did you ever figure it out?
Posted on Mar 27, 2011
Summer infant video monitor beeps frequently that it has lost signal...it does this episodically throught out the night. Is there a solution for this problem? Or is this monitor a lemon?
If the sending and receiving units are going through walls or one is upstairs and the other is downstairs it may not have the range you need as walls will knock down the signal. Sounds like your right on the edge of the range maybe try to move the units closer together if possible and see what happens.
Apr 22, 2017 | Summer Infant Baby Gear
Why does it keep "saying" out of range?
if camera and base are within a few feet of one another does it have a problem obtaining a signal (syncing ) ?? as if it works ok then there might be a object that is getting in the way of the signal , radio waves move from its transmitter (camera) towards its receiver (monitor) in a straight line , if there is too large a mass in the way then the radio wave can't penetrate it and will be "lost" also ck both the camera's and bases battery levels (if they have one) for proper peak power level , as it takes energy to drive the radio signal towards its receiver .
Feb 09, 2016 | Summer Infant Secure Sight Handheld Color...
Summer infant baby monitor has frozen screen
My monitor was stuck on one of my cameras and when I turned it off and on again it was stuck in the hello screen. I took the battery out and put it in again. Then I pressed the button on the left (I have a best view) and pressed the right arrow key until I got to the view can screen. It turns out something was wrong with just one of my cameras as I could view the other one. I unplugged and replugged that camera and that solved my problem!
May 01, 2012 | Summer Infant Best View Handheld Color...
My monitor has lost its pitcher and is saying no camera
The camera is not transmitting an RF signal to the tv, check to make sure the camera is receiving power, if okay! the camera must be dismantled to see if any wires or plugs have come loose.
Feb 06, 2011 | Summer Infant Best View 25" Color Video...
My Summer Infant Best View Handheld Color Video Monitor with 2.5" Screen shut off while I was using it. I thought the battery died so I plugged it in and nothing happened. I left it charging all night and...
I'm having the same problem with the view. I have sound but no picture... I charged it over night and started to use it, But the video keeps turning off and all i get is the sound, i have to keep pressing video on. I have read a lot of peoples problems and this is a major one.... I'm taking it back to babies r us ! so much for 140.00 bucks !!!!!!!
Sep 25, 2010 | Summer Infant Best View Handheld Color...
Baby Care Logo
1,836 people viewed this question
Top Baby Care Experts
masud
masud
Tom Chichester
Are you a Baby Care Expert? Answer questions, earn points and help others
