Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hot washes won't start
Whilst the washing machine works fine on a 40deg wash, the machine just sits and humms when a hotter wash is attempted. Any ideas why?
    Sergeant:
  • 236 Answers
Check the hot water supply is switched on- it sounds like the valve is energising but no water is gettin through !! also check for hot water blockages. easy test is to reverse the water pipes at the back of the machine to test. tony.
Posted on Jun 03, 2007
F&P smartdrive washing machine 4 years old works fine but want the warm water hotter as it is to cold. can i adjust it?
run hot water b4 turning on machine temp are set by electronics can be adjusted slightly for just certain cycles will not make much different turn your water heater up 20 degree its what you want
Jun 27, 2016 | Washing Machines
Which cycle is the hottest
Hi Shonda.
the answer will depend a bit on the specific washing machine you have, and on the settings. There will usually be settings of hot, warm, and cold for both the wash and rinse cycle. A hot wash and hot rinse will keep you at the highest overall temperature during the wash.
There are a number of washers that have internal water heaters that can optionally be activated, usually with a panel switch. This lets them boost the water temperature in the event that the water coming from your water heater isn't that hot - say if you've turned the heater down so that kids won't scald themselves at a sink. The heater option, if there, will make the hot water hotter, though you'd have to look in the manual for you particular machine to see how much hotter.
Conversely, if you want hotter water in the machine, you could raise the setting for your water heater, though you should be mindful of whether this will endanger anyone. You'll also use more energy keeping the heater hotter, so bear that in mind.
Hope this helps, and Good Luck!
D
Nov 18, 2015 | Washing Machines
I HAVE A KENMORE ULTRA WASHING MACHINE IT STARTS TO FILL AND STARTS TI AGITATE THEN THE POWER CORD GETS VERY HOT AND THEN SHUTS OFF THE MACHINE STARTS TI HUMM!! WHAT COULD IT BE ? MOTOR? CAPACITOR,COU
That sounds dangerous. Check to see if it's still under warranty and get it looked at. If it is past it's warranty date contact the store where you bought it, or the manufacturer and find out the cost of fixing it. If it is more than the price of anew one do your washing by hand or get a new machine. To do washing by hand just soak everything in your laundry tub over night and rinse it out in the morning. Hang it out to dry.
Sep 11, 2014 | Kenmore Washing Machines
WT640 Not completing spin cycle.
thats a front loader
the user manual might have the error codes listed
think its a direct drive model
only part of that description suggests its the printed circuit board
are you using a surge protector at the wall power point
Hotpoint WT640 Instructions For Installation And Use Manual
Apr 01, 2017 | Washing Machines
Washer washes but won't drain and won't proceed through the rest of the cycles. It just humms.
hi it sounds like your pump is blocked have you tried cleaning your filter these pumps are magnetic and will sit and hum if blocked
Nov 15, 2011 | Washing Machines
My washing machine fisher and paykel MW 511 will wash fine but when it gets to the rinse cycle it stops. The lights remain the same (no flashing or beeping) and the motor smells hot. It starts again after...
You have a restriction in your drain line or pump. Also you could have a pump going out. It will smell like a bad motor. So check for a restriction first.
Nov 02, 2010 | Washing Machines
No water flowing into drum, water supply is fine, just humms
My Samsung washer was not filling with water after cleaning the debris filter. All I did to fix it was to dump a half gallon of water into the tumbler, then I ran the beginning of the rinse cycle and it worked. It seems like the pump needed to be primed.
Sep 16, 2010 | Samsung WF337AA Front Load Washer
Kenmore washing machine
the belt is slipping if this model still has belts.
lean/tilt it back and look under for belts.
its the belt in the center
Feb 29, 2008 | Kenmore 24032\24036 Top Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
63 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
