Question about Maytag Dishwashers
I have a maytag 3000 dishwasher which the key pad does not light up
It still works but the key pad will not light up too tell what it is doing
Try looking for an option inthe menu where you can increase the light level maybe thatp why you cant see the words.
Posted on Feb 11, 2012
Maytag quiet series 3000 lights do not light up. Unit has power and door switch is working correctly
maytag 3000 washer will not lite up or power on outlet was checked it works.
Aug 07, 2012 | Maytag Dishwashers
My maytag quiet series 300 lock light is on and wont work at all ,what do i do?/
there should be 2 buttons on the control pad, that when pressed simultaneously for 3 seconds will unlock the control.
Oct 24, 2011 | Maytag Dishwasher
The control panel is flashing a L. What does this mean?
Hi.
The model indicated: MDB5651A does not have display and the error codes are shown like flashing lights. If that is your model and problem please just tell me what lights are flashing.
In Maytag with display instead, the L on display means that the machine is control locked. That is not an error message, but a code telling that the machine has been locked by the user (probably by mistake since you are the user).
I quote from Maytag technical documentation:
? If a cycle or option pad is pressed after the controls have been locked, the indicator light next to lock graphic will flash five times. On selected models with a countdown display, the display will flash the symbol "L" simultaneously with lock indicator.
? This option does not lock the door, only the dishwasher controls.
To set :
1. Press the Heated Dry pad for three seconds.
2. An indicator light next to the lock graphic will illuminate when the controls are locked.
To Cancel Control Lock:
2. The indicator light will go off as instructed.
Try pressing the the Heated Dry pad for three seconds. If that doesn't work disconnect power. Connect back and try again unlock (power off does not remove the lock). If that still does not work there may be a faulty part. In that case turn appliance off and give me the full model number.
Start holding down the Heated Dry pad for three seconds. In normal conditions that is enough to get rid of the L and of control lock.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Maytag 24 in. MDBH950AWS Built-in...
Key pad problem
what can i say Maytags have many key pad problems, it is very easy to replace you will need the make , model, s/n to order the key pad board, and the board also has a number on it , The dishwashers are rally bad for keypads
Jan 19, 2011 | Maytag CWE4800A Electric Single Oven
My Maytag dishwasher will not start. I have a concealed touch pad on top. This is the third time it has done this. Every light works but the start button. If I wait a day or two it will start working...
There is a way to reset it when this happens. Do a Duck Duck Go web search and you can get the sequence for your particular model/Maytag. There is a sequence of keys to reset. Do the lights blink when you try to press start?
Let us know if this helps.
Jan 03, 2018 | Maytag 24 in. MDB8951AWS Stainless Steel...
Pots &pans normal sani cycle lighs fashing..wont start lights wont go off..help!
If it is a slow blink on the start button it's something to do with your door switch. If it's a rapid continous flashing it's prob a short in your key pad. If it flashes 7 times, pauses and then repeats you have a fault with your heating element.
If it's a short with your key pad and the unit has water in it - stopped mid cycle you can cut the power to the unit at the breaker, open the door controls up and disconnect the 14 pin key pad connection. There should be a wiring diagram in the toekick cover (at the floor). This diagram will tell you how to do various tests, disconnect the key pad. If your not a handy type person call a repair man and tell him you think youhav a short in your key pad.
Mar 11, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
START BUTTOM DOES NOT WORK
ck your door inter lock . if latch is problem then panel won't work . ( you may have a panel problem . some times the ribbon wher it connects to the pc is not making good connecton .. ****
Dec 23, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Jul 01, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Control panel lights OK; Won't start into cycles
Hey, just had the same problem with my 9150. Moisture got into the electronic key pad. $300 to replace it. I was 5 months out of warranty.
I called 800-688-9900 and Maytag agreed to cover the part and we have to cover the labor. Not completely satisfied but a little bit helps.
Jan 09, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag dishwasher MDBTT60AWW
if you can select different cycles such as rinse only and that light up and then if you change it to normal cycle and it light up,then that tells me you touch pad is working,Check your door switches if those are good and your touch pad is responding, i would replace cpu board.If you remove the kick plate there should be a tech sheet there you can put unit into diagnostic mode with a certain key dance if your touch pad is responding.
Nov 24, 2007 | Dishwashers
Dishwashers Logo
51 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
