Question about Frigidaire FGX831CS Top Load Stacked Washer / Dryer
Fgx831cs1 wont work on spin cycle - Frigidaire FGX831CS Top Load Stacked Washer / Dryer
My washer wont go into spin cycle. I hear a clicking sound coming from the timer. It still wont work. What could it be? Any more suggestions, Huseyin?
if it is not progressing to the spin cycle it could be the controller is faulty
I suggest an technician call to get the proper diagnosis for the problem
Jun 22, 2015 | Washing Machines
Frigidaire fgx831cs1 It won't fill up with water. Suddenly stopped filling up. Been working perfectly. Goes straight to wash cycle. Most likely problem?
Hi Friend, this is Z. I am happy to assist you!
Based on the symptoms you are describing, it sounds like your Frigidaire laundry center (FEX831CS) believes that the tub is already filled. Let's attempt resetting your laundry center. This can be done by either unplugging it or flipping the household for about 10 minutes. If the issue continues, I would recommend reaching out to a qualified technician for a clear-cut diagnosis on the pressure switch.
May 20, 2014 | Washing Machines
Fgx831cs1 wont heat
It's either the fuse, heating element, thermal cut-off or thermostat
May 21, 2012 | Frigidaire Dryers
Frigidaire Laundry Center (FGX831CS1) overflowing.
There are a few issues that could cause the overfilling...failed water inlet valve, failed water level pressure switch, hole in pressure system air hose or air hose disconnection to name a few. Need to have professional evaluate, or it could happen again. Call home insurance if there are water damages to file a claim, and they can handle it from there usually.
May 20, 2010 | Frigidaire FullFGX831C Size Stack Gas...
Washer wont work at the spin cycle phase
you nead to replace tjhe door switch.the part#for the door switch is 8318084.
Nov 14, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing machine wont drain or spin all other cycles work fine
you may have a timer problem just advanced your timer on click ahead when it happenes if it drains or spin replce your timer thanks from giles
Mar 14, 2009 | Washing Machines
Frigidaire FGX831CS Top Load Stacked Washer / Dryer Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
