Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Heating element starts to work and then shuts down after about 5 seconds
  • 57 Answers
You may have a thermal limit switch going bad. These devices are in line with the element to keep the dryer from getting too hot. If one of them is defective, it will shut the voltage off to the element. If you are able to, check the thermal limits and your element, using a volt meter in the ohms setting. If the meter reads open after you hold the leads across the switch terminals, replace the device.
Posted on Mar 03, 2015
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: replaced heating element now it
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Why won't it start?
It should automatically restart.....BUT what happened is that when you unplugged it, you cut off the blower at the same time you cut off the heat element(s). The way it is supposed to work, is the thermostat cuts power off to the elements and the fan continus to run for a per-determined amount of time to remove al the heat from the elements. Then another 'fan control switch' shuts off the fan once the 'residual' heat is removed from the heater. Without that 'cool down' cycle, the hot element had enough 'residual' heat in it to trip off the 'thermal overload' in the circuit. The 'thermal overload'... or...'hi limit'...or...'hi temperature control' is resposible for shutting power off to the element(s) in the event that the blower fails.
Sep 24, 2015 | Heating & Cooling
Why won't it start?
I copied and pasted this answer from your other question as I thought it was the same one Sherry.... Hope it helps you.
Rex4634kq1 element only heats for about 30 seconds, i have cleaned complete lint housin, the element housing and the exhaust tube, all of them checked out fine. what sensor need replace
Most possible that the thermostat , the thermocouple , is faulty or the control unit is sensing the temperature in advance to quit.
You might have to start with the sensor - the thermocouple- check if after cooling the thermocouple the heating works, Next check on the timer controller, If there is a timing loss then it is possible that the controller is shutting off the heater. you might have to access and check the reason for the immediate shut down, if so the malfunction can be this unit.
Aug 26, 2010 | Roper REX4634KQ Electric Dryer
2006 tahoe with heated seats. when the seat is
The heating element in the seat may be failing, even thogh it heats the seat, the element could be causing the circut to spike upon power shut down. Relay takes mili-second to shut down after ignition kill and power feed comes direct from battery. Check amp. draw at switch of bad seat and good seat upon shut down. If bad seat higher that 5 amp difference element n/g. Also check for bad relay as they can short internal and cause problems if primary power cut before switch shut down.
Jan 30, 2010 | 2003 GMC Sierra 1500
DRYERS RUNS FOR ABOUT 5 TO 10 MINUTES THEN STOPS FOR ABOUT 5 MINUTES THEN STARTS BACK UP AND RUNS FOR A 5 TO 10 MINUTES .
sounds like your hi-limit temp switch is getting bad,its located on the heating element case to shut-down the dryer element so it doesn't overheat and cause a fire, they can cause problems
Aug 22, 2009 | Dryers
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Roper Dryer not Drying
Get a thermostat and place it in the exhaust. The thermostat should reach 160 and then shut down and drop to 120 F and start back heating to 160 again on cotton setting. You should hear an audible click when the thermostat opens and closes. If the dryer is clear of lint and blockages then change the control thermostat which is mounted on the blower housing.
Sep 07, 2008 | Roper REX3614KW Electric Dryer
Neptune Dryer
My maytag neptune dryer quit heating, after my wife changed the temp setting on the console from regular, to extra low drying temperature. The heating element reads 10.5 ohms. The thermal cutoff reads 0.02 ohms. The hi-limit thermo reads 0.02 ohms. The power coming into the dryer is 240 volts. What can I check or need to replace.
Dec 05, 2006 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
