Question about Android Apps
How to disable media scanner - Android Apps
I want to disable the FINGER PRINT SCANNER at my STARTUP. I'm using a TOSHIBA PORTEGE M600.
you can disable it in the bios. when the computer turns on, hit F1. then navigate to the integrated devices, there will be an option to enable or disable the finger print scanner there.
We have 5 of these at work and I have had to disable all of them.
Hope this helps
  • 2
Mar 11, 2014 | Computers & Internet
840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
Whenever I am connecting my broadband connection to my laptop no Lan is being detected.
Hello izkho,
Your Local Area Connection network adapter may be turned off or disabled in your Network Connections.
For more assistance, please post more information and specification of your system. (operating system, computer model, connecting media, amount of network cards, etc.)
Best regards,
Ashe
PS Did you mean to post this under barcode scanners?
Aug 19, 2010 | Computers & Internet
Error A000000B enabling scanner. Scanner support has been disable
Looks like laser head does not work and cannot be recognizied by scanner.
Sep 10, 2009 | Zebra Symbol Technologies MC909X-G Series...
Symbol MC9090 scanner disabled
You may need to reflash the OS. you can normally download it from symbol webpage. you will need a cradle and an SD card.
Mar 25, 2009 | Zebra Symbol Technologies MC909X-G Series...
Macafee button stays black saying virus scan diabled but when I run check manualy itsays all systems up to date.Whats wrong?
Its possible the resident scanner is disabled. Right click the scanner icon or check program preferences and locate the option to enable the resident scanner. It is also possible you have malware which is disabling the scanner. No single virus scanner can find all infections.
Run another known good scanner to rule out infections.
Mar 15, 2009 | Computers & Internet
Scanner failure, while booting up, blocks all other functions.
no you can not disable your scanner
you ust have to repair your scanner
if you have any warranty then go for it
or visit any technical person who can check cables and scanning tube of your scanner
Nov 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Android Apps Logo
49 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
