Question about Kenmore HE2 Plus Front Load Washer
Delay start on kenmore washer - Kenmore HE2 Plus Front Load Washer
Kenmore HE3 starts by itself in "delicate" was cycle and fills with water when not in use. Can all this be caused by a bad selonoid??
Check that the machine is not on an auto delayed start. Strange that it starts itself. If a solenoid fails, 2 things happen. They either don't let water in at all, or they don't stop letting water in. If its not on an auto delayed start, I suggest that it could be a faulty main control board . You can stop the machine by turning the water off and switching the machine off at the socket when not in use.
Dec 24, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
Unresponsive control panel on Kenmore washer 110.280 327 01
check and make sure its not set on delay mode first,if so press delay button till it cancels delay time on readout
May 11, 2012 | Kenmore Washing Machines
Delay timer is flashing and locked ini that position
did you select delay wash.... it sometimes happen by accident try delay time button to stop delay wash the hit cancel....
Jan 31, 2011 | Kenmore HE3T Washer
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
I need to cancel a washing cycle in the middle of the cycle.
usually pressing PAUSE/CANCEL twice cancels the cycle and shuts it off allowing you to then re-start the cycle. If not try unplugging it and see if it resets to allow you to start cycle again.
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 665 Ultra Wash FH141493
Hi daryano
I'm Harvey the Master Plumber
You want to know how to get the delay to work?
Most models work this way: Washing dishes the first time sets the favorites and the next time you start it the favs come on automatically provided you haven't changed the settings. So after the first use just hit delay and nothing else and when the dalay time is up it should work fine.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Aug 31, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore HE3 blink the light on delay dosn`t works no botton
Press "end of cycle" button to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
175 people viewed this question
Sal De
fordexpert
Robert Rankin
