Question about Hoover Elite U5061-900 Bagged Upright Vacuum
I took mine apart and it's making a wierd sound what's wrong
NEED IT AWNSERD FAST
My vacuum throws dirt out and hits my feet.
Hi Peggy,
I'm sorry to hear you're having difficulties with your DC07. From what you described, it sounds as if your machine has a blockage. The filter may also need a wash.
Although I note you already took it apart, please follow the steps shown in our online Support guide to make sure you haven't missed anything:
http://www.dyson.co.uk/support/dc07/dc07-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
In normal use, the filter needs to be washed at least once every 3-6 months, as shown in the video below. We'd recommend using cold water without detergent. Leave the filter somewhere warm to dry, such as in an airing cupboard or by a radiator, for at least 12 hours, and make sure you don't replace the filter in the machine before it's totally dry.
This should resolve the issue, but if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 27, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson is making a really strange loud sound. It appears to be working. I just took it apart and cleaned the filter and the wand. When I put everything back together, it started making a heavy whirring...
Check the tips of the beater bar. I "bumped" mine to hard and broke a tip. Still worked! Just noisy. Called Dyson support and they sent me a new one no charge. Note. Mine had a loud whirring and a vibration.
Jan 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My steam mop does not make steam.
how do you get a shark steam cleaner unclogged?
Jun 02, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Dyson turns on and is not sucking. It makes a
I have the dyson dc 27. On the bottom left back side of mine there is a circle, and ball inside of it. I turned it on and pushed the ball and it started working again. Sometimes it doesn't cover the whole and stops sucking air through it.
May 18, 2010 | Dyson DC07i Bagless Upright Vacuum
My Dyson CDC14 Animal just started making a wierd sound coming from the rotating brush area. I already cleaned around the brush, sounds like a fast rattling sound.
Something could be jammed, or not rotating freely, maybe an improper alignment with the brushes, or a blocakage within them. Try to re adjust the brushes :)
Jan 27, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hoover steamvac brushes don't spin. everything else works great. Took it apart and no visible problems
my husband took it apart today and the impellers were gunked up with black stuff.
he used these pictures that someone else generously posted. ours was slightly different in internal design, but they are helpful regardless.
here is an exploded diagram of the 5903, 04, etc. it will help you see if any parts are missing or broken.
http://www.vacuumcleanershop.com/images/Hoover/F5903-900.GIF
parts list if you need some:
http://www.vacuumcleanershop.com/hvrmdlf5903.htm
it's working fine now. sucks much better too. what a difference!
guess for the $179 these things avg, they just need annual maintenance. I wouldn't pay someone to do it though.
Jan 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
NO POWER WHEN I PLUG UP THE VACCUM
I had the same problem when I first bought mine. I let it set for a while and did some online research. I can't remember the site I went to, but it said that this sweeper will shut off when overheated to protect it and will start back up later. I went back and turned mine back on and it was fine.
Jul 27, 2008 | Hoover U5507900 Elite Rewind Bagless...
My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Jul 07, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Hoover Elite U5061-900 Bagged Upright Vacuum Logo
24 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
