Question about Brother Sewing Machines
Or-770 embroidery machine has locked up
The machine has locked up, can't lift or lower needle
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
bargainbox
  • 1388 Answers
SOURCE: threading the needle of the embroidery machine
You may need a magnifying glass to see the tiny hook that should pass through the needle eye to catch the thread....
....if it is not aligned properly and does not go through the eye you will need to realign it....
...there may be a small screw attaching the mechanism, loosen slightly with jewelers screwdriver so you can move it but there is still some friction and gently engage the needle threader to see how far you need to move it, then gently, using a fine screwdriver, tweesers etc, nudge the tiny hook a little, check result and continue to adjust until remedied....re-tighten screw.
If there is no screw adjustment, a gentle bending will resolve the problem............but if there is no tiny hook, it will need replacing.
They are not easily broken, but only use gentle pressure to be sure.
Posted on May 23, 2008
akylas
  • 26 Answers
SOURCE: brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Posted on Jun 10, 2008
  • 7 Answers
SOURCE: embroidery machine needle breaking
make sure your top thread is feeding properly and not catching on the spool or twisting as it comes off the spool. When i use metalic thread, i put it in a small can beside my machine and it works great.
Posted on Jan 03, 2009
  • 1116 Answers
SOURCE: Elna 8200 embroidery machine. Broken needle
Computerized machines need to be serviced by an authorized sewing machine technician, preferably Elna.
Diving into this may cause more problems and end up costing you more money for repair.
Posted on Mar 13, 2010
How do I change a needle on a brother 770?
same old way as all machines loosen the screw/clamp and pull it down
Feb 12, 2015 | Brother PE-770 Embroidery Machine
At start up machine says press needle position button. All that happens is the motor revs up then says safety feature has been activated. Any ideas?
I used this machine in my middle school classroom. That message was in the first start up of the machine, I think it just resets the machine. The larger model also has a beginning reset button that just adjusts the arm of the machine. Is the machine working fine after the reset? Hopefully "sew"
Jan 13, 2015 | Brother PE-770 Embroidery Machine
My button needle won't release the needle
I think you should consider a little oil if it's metal parts - it is a small spring that holds the needle in place
Aug 29, 2014 | Brother PE-770 Embroidery Machine
Troubleshooting Brother PE 770
Usually this is a tension problem. On mechanical machines, you'd adjust the dial, or possibly even the bobbin tension. But on a computer machine, I don't know how you set the upper tension, sorry to say.
Sometimes it can help to unthread and rethread a machine, and I don't know why it sometimes works, but it's a simple thing to try.
But if the upper tension isn't set correctly for the work being done or if the tension mechanism, however that's handled on a computer machine, isn't working correctly, this is what happens. Bird's nest is a good way to describe it.
Sometimes lint built up in the bobbin case can cause this symptom too, but I'd assume you keep this area clean. One reason I haven't yet invested in a computer machine is because problems like this often don't have such simple solutions as on the mechanical machines.
Jun 30, 2014 | Brother PE-770 Embroidery Machine
Brother Sewing Embroidery Machine
I agree with sylviaivie about find another repairman, they are suppose
to guarantee the work they do.
when the upper shaft is replaced & then the machine is retimed
the machine should work just fine.
but just don't take it back to that man to be repaired
here is a tip if it happens again,,
always try to cut the top thread first,
& turn the machine up on it's back to access the bottom cover
take the cover off the bottom to get access to the bobbin thread
where you can cut the bobbin thread
then you should be able to get the needle out without breaking it &
damaging the upper shaft, replace the needle & make sure
that the thread is good quality & not knotty, clean out the bobbin area of lint or thread
always change the needle on the embroidery machine every project
make sure the bobbin area is kept clean of lint or thread
clean under the needle plate at least once a week for lint if you
embroidery everyday or just often
Aug 01, 2012 | Brother Sewing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Machine embroidery needle changes position
truthfully I think their something wrong with the computer in the machine because
the bobbin locked up. sometimes when a sewing machine jams it can make
the machine jump time.
but the needle moved positions, some part of the machine is changed during the
jam up, even tho you reset it.
embroidery machine are expensive, my suggestion is to have the machine checked
Apr 05, 2012 | Sewing Machines
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Sewing Machines Logo
19 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
