Sylvania model LC320SS9A WILL NOT STAY ON
When power is turned on the light will turn green for a few seconds then will shut off. Screen will turn on for about 2-3 seconds
  • 8 Answers
SOURCE: power on
Depends on how many times it flashes RED.
On the units with fans (usually the HD models) a 6 blink flash code indicates improper fan rotation and the unit will shut down.
These blinks are counted as they go DARK, not as they light up.
Remove the rear panel but do not clean out the dust from the fans until you see which has the improper rotation.
Cleaning may help once you find the baddie, if not they will need to be replaced.
T Wiz
Posted on Mar 25, 2008
SOURCE: just black screen
Hi i have the same problem i think it is the power board you can buy these on ebay for about £200 i havent botherd as yet as i might just buy another tv as ive had no end of trouble with it dont think i would ever buy a hyundai tv again!!
Posted on Apr 30, 2008
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
Posted on Feb 17, 2009
dsacco86
  • 1077 Answers
SOURCE: New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Posted on Jun 01, 2009
ladywinn
  • 5138 Answers
SOURCE: Will not operate power/volume for
What kind of remotes do you Have?
Posted on Dec 31, 2009
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Sylvania lc320sl1
in this television .if you see the digital television .its the inverter board. try a probe pull off the small cable of inverter board .and try to turn on the tv .if the light stay green the inverter is out. thanks
Dec 10, 2013 | Televison & Video
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
Power light just blink on my sylvania lc320ss9a lcd
It can be the power supply is unstable due to bad DC filter caps, or it is sensing short circuits caused by backlight board, you will have to take it apart and start by visual inspection first, look for bad caps iwth leaking/bulging tops (caps can look OK but can have high ESR). Then you need to do voltages checking.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 14, 2010 | Sylvania LC320SS9 32 in. LCD TV
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
