Question about M-Audio BX5a Speaker
I need a low frequenct driver for the bx5a
Just need a replacement the woofer is blown
Peavey problems
I assume you mean the Pr-12RX passive? That seems wrong to me, too. Put an ohm meter across the terminals of the horn driver and the woofer seperatly to see which, if either, is blown. If they're OK, look for a bad solder joint on the crossover.
Jul 28, 2014 | Peavey PR 12 Speaker PA Passive
Audio bx5a tweeter
Tweeter just may need to be replaced. Is all the sound coming only from the woofer?
Apr 04, 2014 | M-Audio Audio Players & Recorders
Crackling sound in speaker
These speakers have a history of being blown if played too loud. Apparently the higher quality CX version are reliable. If the lows are what is crackling, the voice coils are probably cooked causing it to drag the pole pieces.
Apr 28, 2011 | M-Audio Studiophile BX5A Deluxe
Sounds as if the woofer is blown. seems t be a vibrating noise. this will be the third time fixing this problem.
get some higher rated speakers as this will happen time after time, or you could turn the bass down lol
Apr 08, 2011 | M-Audio BX5a Speaker
So I've kept my Studiophile BX5a Deluxe monitors in good shape, but I noticed that every sound I tried to generate via Ableton Live on my Mac, a buzzing sound would accompany the sound. For example, I...
See if you can isolate the buzz to one woofer or tweeter. If a woofer, gently and evenly move the cone in and release to feel / listen for scraping. If you notice any scraping, the voice coil could be shot - a small bobbin of copper wire may have deformed andis now rubbing. Occasionally if a speaker is dropped, the magnet can shift, which will then rub the coil.
In any case, if there is coil rub that causes the buzz, you need to replace that driver.
If the buzz is electronic in nature, assuming these are the powered versions, a qualified service tech will have to diagnose and repair.
Jan 06, 2011 | M-Audio BX5a Speaker
Where do I find a replacement woofer for a bx5a monitor
http://reconingspeakers.com/product/m-audio-bx5a-woofer/
Jan 02, 2011 | M-Audio BX5a Speaker
Driver side speaker and sub woofer make an popping
they could be blown try replaceing them and see if it helps
Jul 27, 2009 | Car Audio & Video
Do you know if my woofer is blown?
well if you hear a rattle sound its probably already blown...and the amp could be drawing too much power if the radio shuts off...make sure all your wiring is correct. also if your car is off and you turn it up it will most likely shut off cause the battery cant handle it. but as for the sub i think its blown. good luck
Nov 16, 2008 | Jl Audio 12W3 Car Subwoofer
Amplifier
Yes. Most likely your factory speakers are blown as I've seen this many times. They are co-axials (2 ways) and the woofer part of the speaker is blown or the surround is rotted and only the tweeters are playing. I also believe that the front door speakers are low frequenct. Are they playing or buzzing?? Let me know and I can confirm this as the solution. You need new speakers.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jul 01, 2008 | Car Audio & Video
The red light on my amp keeps coming on and it wont work
You need to check your woofers. Most likely one or both may be a) blown or at a dead short or b) the ohm rating on them may be too low. What model woofers and amp do you have??
Nov 17, 2007 | MTX Thunder TA7801 Car Audio Amplifier
M-Audio BX5a Speaker Logo
52 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Carlos L. Burgos
Carlos L. Burgos
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
