Question about Toshiba Satellite Laptop / Intel Core i3 Processor / 15.6" Display - Helios Black (L655S5117) PC Notebook
Toshiba L655-s5117 won't stay on
  • bob michaels Feb 11, 2012
    toshiba L655 when unplugged from the ac adapted it won't even turn on.
    when plugged in with the ac adapter it starts up, gets to the 1st toshiba screen, then shuts off. Ive tried the F8 button, taking out the battery, holding down the power button, etc. from previous people with similar problems. computer does not get overused. its 2 yrs old. It all started 1 mo. ago after i downloaded updates from toshiba when they notified me to update my bios. then everything hit the fan since then. toshiba wants me to pay to have it looked at! anyone else have this problem??
    Master:
  • 388 Answers
CPU is over heating needs to be re greased not an easy job would recommend taking it to a shop for repair using it in this state can cause critical irreproachable damage
Posted on Feb 11, 2012
2 Suggested Answers
  • 561 Answers
SOURCE: toshiba sattelite l655 can't detect webcam..pls. help me
Did you install the latest Toshiba webcam driver if not , go the toshiba official website and download the lastest software for your laptop computer
Posted on Dec 03, 2011
I have a toshiba satelite L655-s5117 laptop and it won't boot up even when i try and boot from windows 7 disk it won't
Probably a faulty hard drive. go into the setup screen and verify the HD setting is correct. save your settings and reboot. if this doesn't solve it, then take out battery and disconnect power, remove hard drive and reconnect. try reboot. if none of that works, then replace hard drive and reinstall OS.
Mar 10, 2013 | Computers & Internet
Sound not working
You need to set the the Default audio device to the speakers in the Control panel and make sure the sound is not "muted" (turned off)
Feb 18, 2013 | iTEKIRO Laptop AC Power Adapter Notebook...
My L655 Satellite won't start up
Is it plugged in? Is it getting power? Can you be more spectfic?
Dec 17, 2012 | Toshiba Satellite L655S5058 Notebook PC
L655 Satellite won't start up.
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Toshiba Satellite L655 AC Adapter 65Watt 19V 3.42A
Replacement Toshiba Satellite L655 AC Adapter 75Watt 19V 3.95A
Dec 17, 2012 | Toshiba Satellite Pro A210-EZ2202X...
My Toshiba Satellite L655-s5107 won't turn on.
More than likely the power cord/charger is dead or the battery is. Bring it to a tech store and see if you can test out a new cord/charger and battery......
Jun 29, 2012 | Toshiba Satellite L655-S5107...
I'm using a Toshiba Satellite L655. Whenever I
open control panel
mouse icon
check settings
if all ok there then it might be that mouse drivers kaput reload from website or disc
May 24, 2012 | Toshiba Computers & Internet
How to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
Apr 15, 2012 | Toshiba Satellite L655-S5160 Laptop PC...
Satellite L655D-S5093 keyboard removal
This is the User's Manual for the L655-S5098 laptop:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2759985&rpn=PSK2CU&modelFilter=L655-S5098&selCategory=2756709&selFamily=1073768663
Predictably, its useless when performing maintenance such as keyboard replacement, but page 82 indicates that this laptop supports "most USB-compatible [external] keyboards", so, while the chicklet keyboard is down, you can boot and use the system with a workaround USB keyboard.
I could not find an L655-S5093 laptop model on the Toshiba support web site, which is found at http://www.pcsupport.toshiba.com
The closest I could locate for you are these two How-to Guides:
Here's a teardown of the Toshiba L645/L645D laptops:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/remove-laptop-motherboard-1.htm
Here's a teardown of the Toshiba L675D laptop:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/dismantle-laptop-1.htm
Nov 27, 2011 | Toshiba Computers & Internet
My toshiba laptop satellite L655-s5096 was installed win 7, i format it and install win xp SP3. once am installind sound drivers and modem driver after extracting it does not install it, i tried to find a...
Where did you get your drivers from? Make sure the drivers are compatible with Windows XP, Vista/7 drivers generally won't work. You can probably get the XP drivers from Toshiba's website.
Oct 01, 2011 | Toshiba Satellite L655-S5096 Notebook
Toshiba Satellite Laptop / Intel Core i3 Processor / 15.6" Display - Helios Black (L655S5117) PC Notebook Logo
201 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
