Question about Acer Aspire One Netbook 8.9" Notebook
VGA connection-acer aspire S610 to Bravia BR2, What are the compatible display resolutions?
    Master:
  • 388 Answers
Contact Bravia support
Posted on Feb 11, 2012
SOURCE: Acer Aspire 5610 Notebook driver download
Cannot setup VIDEO driver for my Acer Aspire 5610... Trying to setup driver from this website... Please help!!!
Posted on Jul 09, 2008
pagebor
  • 2785 Answers
SOURCE: My Acer Aspire 5600 has a driver problem
you can check the manufacture website for the drivers
Posted on Jul 22, 2008
  • 244 Answers
SOURCE: All Drivers for Acer Aspire 3680
you can download from www.acerpanam.com
Posted on Oct 01, 2008
ejkudelka
  • 1188 Answers
SOURCE: Display Resolution for Acer Aspire 6930-6455
For the 16" Acer 6930-6455
WXGA - Cinecrystal - Active Matrix -
Resolution: 1366 x 768
Posted on Sep 29, 2009
Testimonial: "Thanks a lot!"
parrotheadpc
  • 2600 Answers
SOURCE: Can someone help me connect my Acer Aspire 3680?
Your graphics card on that should push that resolution so I would probably lean toward the tv. Try changing the aspect resolution or (zoom button) on the remote to change the way the screen is delivered. As long as the resolution on the laptop is a widescreen resolution and the same for the television. Make sure in your tv settings, that the aspect is set at 16:9.
Posted on Jan 12, 2010
Cant connect my acer aspire 5334 to sony bravia tv
Your laptop and Sony Bravia LCD tv has the VGA connector.
It looks like ..
Connect your laptop to Tv using vga cable.
Thanks for using FixYa.
May 23, 2011 | Computers & Internet
How do I connect my acer travel mate 4010 to my sony bravia tv using a vga cable. everything is plugged in but can't get picture on my tv.
Compare the resolution settings on the Travel Mate 4010 with the available resolutions on the TV. You must set the display resolution and vertical refresh rate (sync rate) on the Travel Mate to match one of the formats used by the TV. You will probably have to look in the manuals for both units.
Apr 02, 2011 | Computers & Internet
Can you please tell me how to connect aspire 3000 to an hd tv
If there is a VGA output or a HDMI output then you can buy the VGA to HDMI cord at most electronic stores, just check the resolution compatibility with the TV, but it should work, good luck.
Mar 14, 2011 | Acer Aspire 3000 Notebook
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
How do I connect Acer Aspire One to sony bravia tv?
Then use a VGA cable to connect to the PC IN on the TV.
May 01, 2010 | Acer Aspire One PC Notebook
I have an acer aspire 5535-6637 and I was wondering if it is compatible with an S-Cable.. If not how can I watch things on my laptop from my TV. Thanks!
You may or may not be able to, it depends in part on your TV. The earliest interface that was compatible would be VGA but it may not be very good on resolution.
The specs for your notebook show only:
DVI Port, VGA port
The DVI (Digital Video Interface) port is available on later sets so check your user guide for either of those two and if VGA is the necessary choice, check which resolution the computer and TV share. DVI will adhere to the same standard for both.
BTW, when asking for help when interfacing devices, include model numbers for both; it saves us time and will give you a more accurate answer with fewer generalities.
Mar 27, 2010 | Acer Aspire 5535-5050 Notebook
Trying to connect vga cable to tv get format not supported
Adjusted screen resolution to a compatable one for the lcd tv
Jun 02, 2009 | Acer Aspire M1640 Refurbished Intel...
How to connect acer aspire mini laptop to digital lcd tv?
You get the audio from PC: you must use a separate audio cable to your TV audio input.
Configure your PC Display properties to a lower resolution until you reach a format your tv can display.
If you use a flat digital screen check the manual to know the resolution to be used with VGA input.
Use Dual screen option or swittch main screen/external/both using FN key + blue key showing screen on your keyboard. (F4 or F7? check manual.)
Jan 07, 2009 | Acer Aspire 5100 Notebook
Acer estensa 5620
Might be something wrong with your display settings. Between the Acer logo and Microsoft logo, try pressing F8 about twice per second. A menu appears. Use the arrow keys and choose the one with "VGA-mode" using the enter-key. Wait while the computer boots. Set a compatible display resolution for your display.
Nov 03, 2008 | Acer Aspire 5610 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
