Question about Abit IL-90MV (00841020003868) Motherboard
Bsod and VIIV not install
Hi i have done a clean install of windows media centre with 1 gig of ram and mobile cpu merom t5600 1.83/2m/667.
Before i did anyother installs i got the full updates and the HD audio driver from windows update.
Then installed all the lastest drivers etc chipset GFX....
But on the disc and on abit website there is the driver for the VIIV and IFF these will not install as it say platform not supported.
And i get the BSOD windows says its the HD audio driver (but i got the driver off them)
Last thing is when i change screen settings to HDMI output at 1080p the screen is to but to show all the desktop on my 40inch LCD T.V.
Many thanks
Dave
    President:
  • 2,351 Answers
Hi Dave,
When performing a fresh install of windows, the very next thing that a user should install are the drivers from the motherboard CD. (This means install the Intel chipset software utility)!
(Do not run windows update service's first)!
Install all the drivers from the manufacture, "EXPECT the, Viiv software driver". You'll need to get media center updated to SP1. Than install the Intel Viiv software.
Once the system is stable, than you can download & install updated drivers from Abit.
(Check the date of the drivers on the CD against the drivers on Abit's web site & download & install the latest drivers). Check that the system functions correctly. Check your bios. See the bottom of page 3-10. in your manual, HDMI Port Display. Than read page 2-17. Realtek uses jack detection software.
Than continue with windows update services.
I'm not sure about the last issue in your post. I think you are saying the TV is not showing all of your desktop! Check the display settings in your TV & set you desktop to display to 1600 X 1200 @ 60MHz. You might have to play with the desktop resolution rate to get all onto the TV.
PC display to TV display is not a strong point for me. I don't want you hanging on the display issue so I'm going to suggest you post this issue with a fellow expert. Click the Ask me button on Benimur's link. He's pretty good at item like PC to TV. http://www.fixya.com/users/benimur
Abits web site link:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=iL-90MV&fMTYPE=Mobile%20Socket&pPRODINFO=Driver
Good luck Dave!
Mike
Posted on Oct 25, 2008
BSOD AFTER CLEAN INSTALL 2X
Since you are getting the same result from the same actions I would say that you should change the hard drive. It may be defective.
Mar 16, 2014 | Gateway NV79C48u Laptop
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
Ram compatibilty
Yes you can but the higher spec DDR2/800 RAM will run at at lower speed same as the DDR2/ 667 RAM.
When you install the DDR2/800 RAM and the BIOS only detects 1Gb of RAM then this RAM is not compatible with the 1st RAM module. In this case use RAM module that is the same make and speed as the original RAM module.
May 03, 2012 | Computers & Internet
HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed ..to upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
Memory:
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Feb 06, 2012 | Gigabyte Computers & Internet
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
Mother board 533 prescoot how the accpet ram and processer
This motherboard supports DDR2-800/667/533 Memory and any socket LGA775 CPU such as Intel Core 2 Quad, Core 2 Extreme, Core 2 Duo, Pentium XE, Pentium D, Pentium 4, and Celeron LGA-775 CPUs
Feb 01, 2011 | Asrock Pentium 4 (LGA 775-pin) -...
I want to upgrade my from 512 to 2GB RAM. Pls let me know which brand RAM and speed will suport to upgrade the same. my motherboard is P5RD2-VM, with intel pentium D 820 processor. pls guide me on the...
Your Motherboard will support:
2 x 240-pin DIMM's (4GB Max)
Unbuffered
non-ECC
667/533/400 MHz DDR2
You should be pretty safe with any main brand name of memory from your local computer shop.
Below is a list of ASUS TESTED and Qualifed Vendor RAM.
Jan 02, 2011 | ASUS P5RD2-VM Motherboard
Blue screen of death, cant seem to be stable after trying everything . thinking it may be a memory timing issue, using 4 gigs of drr 500 mushkin redline. will give further discription if you tell what info...
It could very well be the timing but it may also be the voltage setting. find the specs for the memory from their website, timing and voltage and enter your bios and make sure the voltage is set to the right parameters. The timing isn't as critical as correct voltage. I also wonder if changing the memory positions may be causing the error. My mother board made me use slots 3,4 not 1,2 kinda strange but when I switched them no more bsod. And remember windows 32bit systems will only use/show 3.2 gigs regardless of how much physical ram is installed. I hope this helps you and good luck.
Aug 11, 2009 | DFI LANPARTY UT nF4 SLI-D Motherboard
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
thanks
roger
Nov 12, 2008 | AOpen AK77-8XN Motherboard
Abit IL-90MV (00841020003868) Motherboard Logo
96 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
