How to remove gold foil from motherboard - Computers & Internet
  • 807 Answers
What foil, if you mean recover the gold on the connectors etc, then you need to use chemicals / acids. Look on youtube for reclaiming gold from electronics.
Posted on Feb 11, 2012
Brother dcp-130c flat cable
if you want to damage your device you can use tin instead of gold.
Jan 22, 2014 | Brother DCP 130C All-In-One InkJet Printer
Is it easy to find gold on a beach with a metal detector?
Gold is more valuable than silver and often comes with gem stones etc, so finding it on the beach is a great thing. But - gold has low conductivity and falls into the same range as pull-tabs and foil. So if you sift those types of items out, so that you don't' get so much junk, you could also be sifting out the good stuff.
Feb 21, 2013 | Retail Supplies
My MX700 canon printer is flashing the on ff green light and the gold alarm light and say error code 6A80. My book says to unplug all power and the plug back in but it is doing the same thing. Thanks for...
The printer head has locked itself and won't move.
I have found a solution for you on the Internet - here are the details :-
I was able to unlock the print head - just with a small piece of foil.
Cut a 3-5cm wide stripe from a sheet of overhead-foil (90um thickness), move it below the print head, and move it to the front and upwards, to the back and upwards. Remove the foil. After switching the printer on - it will work as before and be able to move the head. No need to disassemble the whole MX700!
Leo.
Nov 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I want to print metallic gold and gold-foil TITLES on a standard CMYK background with an Alps 5000P. What is the procedure to overlay the spot color where I want to print the gold?
Create a mask or layer for each spot color you want to print using only black. When printing spot colors anything on the mask in black will be printed in the spot color. For foils, print a couple of layers of black ink before you print the foil to get a very good effect. Remember to check the overlay option so the paper doesn't get ejected.
Nov 11, 2010 | Alps MD 5000 Thermal Printer
How do I print using the foil ribbons? I do not see Gold foil as a color choice.I am interested in any info from a manual on this subject of gold or silver foil ribbon printing.
Your ALPS MD-5000 MUST be set to print in DYE-SUB. mode.... Is there a Memory upgrade plugged into the slot next to the Printer Port? If not, then it's not an option......
Feb 11, 2010 | Alps MD 5000 Thermal Printer
Compaq presario 6310ca not able to upgrade memory more then 512mb
Hello sir, hi, your compaq can handle 1.0 gb of ram using pc2100 ddr sdram, If the modules cannot be detected, clean the Memory slots with a clean paint brush, and the ddr gold foil cleaned with an eraser. Make sure when you snag it on the slot, you hear clicks. for more info check out this website: http://www.memorystock.com/CompaqPresario6310CA.html
Do the cleaning and eraser several times, If still nothing happens, check out your memory module, they may be bad.
Nov 13, 2009 | Compaq (261671-001) Motherboard
How do I format a Word document to print on a Maco gold foil certificate label, ML-7850? Thanks.
Maco Laser Gold Foil Notarial & Certificate Labels
Personalize awards using your own laser printer.
* Can be used for legal documents, certificates, embossing and more.
* 2 1/2" diameter with serrated edges.
* Designed for laser printers only.
Choose the correct label size from the page setup in MS Word.
Apr 13, 2009 | Computers & Internet
I caint get my alps5000 to print out silver and gold foil
First of all, are you tring to just print gold foil, or a multicoloured image, including gold?
If it's just gold, ensure that on your artwork, everything to be printed is black. Click File -> Print, and click Properties.When the printer dialogue pops up, select Spot Colour, and click the Spot Colour button. Select Single Ink, and Select Gold Foil.
Jan 03, 2008 | Alps MD 5000 Thermal Printer
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
