Question about Samsung DVD-VR375 DVD Recorder/VCR
Playing a recorded dvd from dvd-vr375 on another dvd player
I can't get discs I've recorded on the dvd-vr375 to play on anything but that dvr/vcr recorder. Is there a way to get them to play elsewhere or do I have to have a 375 everywhere I go to watch my recordings?
  • 4 more comments
  • Anonymous Nov 03, 2008
    I've tried to play recorded DVD's on other players with no success.
  • ellalow Jan 03, 2009
    I tried using DVD-R and DVD+R, and neither worked on other machines, including other Samsung machines.
  • Anonymous Jan 04, 2009
    I had the same problem. The fix was I just needed to FINALIZE the disc-Gary in Ky.
  • The Akumalia Jan 30, 2009
    I HAD the same problem with my Samsung DVD-VR350, and after reading the comments here, I solved the "problem" by Finalizing the discs.
  • Anonymous Mar 01, 2009
    cannot play recorded dvds on any other player or computer
  • Anonymous Mar 26, 2009
    Cannot play back the recorded DVD
If you are using DVD-R media, you can record in either V or VR mode.  What is confusing is that if you try to format the media, you only have the choice of VR mode -- and this mode is very well understood by other dvd players, some other records do understand it.  This mode has much better editing capability, but poor compatibility.  If you want compatibility, use the V mode.  The trick is that to do that, you don't format it!   V mode is the default and does not require formatting.  The owners manual says that, but too well hidden if you ask me
Posted on Mar 02, 2009
  • 32 Answers
Check the mode of recording, there are two types, one being editable will not play on most other devices.
2. check whether the discs are finalized
3. If you are using re-writable discs, you may not get the option to change the video mode, so try using regular dvd -r or +r discs.
Posted on Nov 13, 2008
  • 3 Answers
I called Samsung. They said to use the dvd-r instead of +r.I'll post tomorrow and let it be known if this corrects the issue.
Posted on Dec 22, 2008
I have a zenith dvr/vcr and the finalized disks cannot be viewed on other devices. I have finalized it dvd+r.
The suggestion provided by Orion523 might work. Have you tried not finalizing it and seeing if it will then work in other devices? I assume you mean you are using DVD+RW disks. Good luck.
Jul 11, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
After dubbing from vhs to dvd, the dubbed dvd is placed into a PC but it comes up saying the dvd is blank..We used a dvd+R dvd. Any ideas?
First did you finalize the disc after dubbing? When the DVD/VCR recorder is in stop mode, press Menu and navigate to Disc Settings > Disc Finalize and select Finalize and press Enter. Select OK and then Enter again. (Navigate the menus with the up/down arrows followed by pressing enter. Use the right/left arrows to highlight an option.)
If the disc was finalized, try a different brand of DVD+R or a DVD-R disc. I've seen some DVD recorders that don't work well with some brands or types of discs. (The same can happen with computers - burning a coaster.)
The manual is available here: .
I hope this helps.
Jan 25, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
When I insert a DVD-RW disc in my DVD-VR375 it tells me 'this disc can neither be played nor recorded'. Why is this happening?
This message alert prompts you check and make sure that there is no dirt or scratches on the disc.If so clean the disc surface with a soft dry cloth and try again.Please don't use any liquids or solvents to clean the disc.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jul 23, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
After recording a program on a DVD+R disc, the TV screen says "Disc Finalize Processing...." and nothing else works. I can't stop it, watch it, finalize it, or power off.
The DVD burner in your DVD-VR is defective. Get it replaced at a service center.Is is not able to read the lead in lead out information from your disc. Try playing one of the disc you have written on another DVD player.
Mar 10, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Want to unlock region codes on my Samsung vcr/dvd recorder model no dvd-vr375 so I can record here and it can be played in Canada
Do the following step to make your DVD player region free..
1.Turn machine on without disc inside
2.Press menu button
3.Enter region code (See below for list)
4.A highlighted 'region area number' will appear in the upper left corner (some players)
5.Press 9 to change the region number to multi-regional
6.Turn DVD off (remove power from mains)
next time when u power on the DVD ,it will be region free.
region 1 - 29334
2 - 38767 or, 5 7 5 3 8
3 - 56732
4 - 76884
5 - 53814
6 - 24462
Jan 22, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Tried dubbing VHS to DVDs, worked okay. But I cannot get the DVDs to play on my laptop. I used DVD-RWs. What kind of DVD do I have to use?
It depends on the specifications of the DVD drive in the laptop. Go to the website for you laptop manufacturer and look up the specifications. You also have to have DVD playing software. It is was not always included with the Windows operating system, although some kind of player may have been packaged with your computer when sold. DVD-RWs are recorded at slower speeds, which makes bigger dots and make not work with all DVD playback drives.
Jan 09, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Dvd-vr375dvd not playing some discs
try cleaning the lens but be careful when doing this,also your dvd machine may not be compatible with other disc formats, normal dvd players can only play dvd video and some vcd. Not all dvd players will play DVD-R/Rw or DVD+R/Rw discs, check your owners manual.
Aug 14, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
When I record a dvd on my vr375 it will not play on my DSE dvd player .I am useing a Sony -RW DVD
before the disc will play on other players, you need to "finalise" the disc. Finalisation ensures compatibility with other devices. Go into the "Setup" menu, and look for "Disk Manager", there will be a finalise option. select the option, and after approx. 3mins the disc will play on other players.
Jul 18, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Toshiba dvd/vcr combo
how can i explane it the dvd recorder has its own built in format that stops other dvd players from playing the discs in them they also dont work on the pc either ive tried
Feb 17, 2008 | Televison & Video
Samsung DVD-VR375 DVD Recorder/VCR Logo
506 people viewed this question
Jerry Greenberg
Jerry Greenberg
