Question about Logitech Z-2300 Computer Speakers
Very quiet subwoofer
The subwoofer on my Z-2300 seems to be broken. The satellite speakers work fine but the sub is not audible during normal play, even with the bass setting as high as it will go.
It is not entirely broken however. If I unplug the satellite speakers and turn the volume up to max the woofer can he heard feintly. I have checked all the computer settings and I am sure it is not a problem with this.
Is something wrong with the amp? If so is it fixable by a professional or is it time for a new system? (it is out of warranty 3 yrs old)
I had the same problem until I decided to plug the speaker system into my desktop instead of my laptop. Now, all is well and I had to turn the bass control almost all the way down... I was shaking the house! Must be something to do with the quality of the laptop output.
Posted on Dec 17, 2008
Why does it play and stop but monitors work fine?
Some subs are switched on and off according to the level of the input signal. The purpose of the switching is to prevent initial "pops" and sub-audible pulsing from damaging the speaker. To the listener, however, it creates the sensation of a sudden loss of hearing followed by restoration.
Jan 21, 2016 | Samson Resolv Sub88 Subwoofer
Why does my MCS sub 10 not turn on?
Is that the right part number, MCS 10, and not MCS100?
The MCS systems use a basic sub which is matched to the satellites. There's very few controls other than level on the MCS100. So as long as the power light is illuminated the there's very little other than the volume control that could be set wrong on the sub. So what it comes down to is either
  1. a blown fuse (no power at all at the sub);
  2. a broken input (#1 cable, #2 sub input socket, #3 blown sub plate amp);
  3. incorrect connection at the receiver end or the wrong settings
As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay
Switch off the sub and reconnect the phono/RCA to the sub out socket on the receiver. You now know it is connected correctly.
Go in to the receiver's menu and check the speaker settings. Is subwoofer present? Yes/No
Are the satellites all set to Small? (they should be with this system)
Are you playing a 5.1 source in DD or DTS to ensure that the sub gets a signal? Play a BD or DVD.
On the speaker balances, is the sub channel set to 0dB?
As long as all the above is set as listed, then the only things stopping the sub working would then be insufficient volume at the sub's Vol control (so increase it), or an intermittent cable connection (wiggle the cable), or a broken subwoofer out signal at the receiver.
Aug 06, 2014 | Boston Acoustics Audio Players & Recorders
My wharfedale sw150 subwoofer cuts out in normal viewing, any suggestions
If your Wharfedale sub is powered, it gets its input from a subwoofer output on the rear of the Sony. At a certain level, your sub is turned on and sounds just fine until the level decreases during quiet passages of music then it turns off. I believe the theory is that this approach prevents start-up "pops" but in practice it is a poor solution. I have had several subs that have acted this way. I don't know of a way to fix this short of eliminating the level-controlled turn-on circuit
Sep 28, 2012 | Wharfedale SW150 Subwoofer
My satellite speakers are no longer working, logitech do not issue replacement satellites. Do you know if their is a way to use alternative sattelites with the subwoofer?
the back of the sub has 2 rca connections for left and right speakers so all you have to do is either find satellites that use rca connections or find or make your own "clip-on" or detachable wire to rca connection.
Dec 24, 2010 | Logitech Z-2300 Computer Speakers
The left satellite has stopped working, sound does not come of it. The left one works fine and so does the subwoofer, however the on left one not working is becoming very irritating.
Have you checked if the amplifier is working??? Maybe the saund generator (Compiuter, TV etc.) is set to only play on left, check balance, and CHECK THE CABLES
Aug 10, 2010 | Logitech Z-2300 Computer Speakers
Logitech z-2300 subwoofer not working
ahh logitech always the sub that goes. its buggered but dont toss out the whole speaker set just buy another one and youl have spare speakers when you need them
Jul 28, 2010 | Logitech Z-2300 Computer Speakers
Bought a used Martin Logan Dynamo subwoofer a couple days ago and have a very loud hum when the ac cord is plugged in, even if the speaker is not connected to an audio source. The "hum" can be heard in any...
Neither the amp or the sub have grounded power cords.
I have discovered the ML Dynamo takes about 30 minutes to switch to standby in auto mode.
With speaker level inputs connected to the Onkyo A807 amp, both units powered from the same wall outlet, Dynamo sub on Auto, the sub hums for about half an hour after the Onkyo is switched off, then the sub goes quiet. Not so good.
I connected a bonding wire between the two units on 3_7_09. If I smoked some old audio gear I could just look at that as an opportunity, right?
Works fine. Now I have the ML powered from the wall and working normally.
Jun 30, 2009 | Dynamo MartinLogan Subwoofer Speaker
Very Quiet Subwoofer - amplifyer problem?
Yes, it is fixeable, but you can carefully check this,
1) open the SUB, and see if any cable is broke or loose in the negative and positive poles.
2) check if there a loose cable on the terminals point of attach speakers.
3) other than this is a defective AMP inside and mus be change.
open sky
Mar 13, 2009 | Logitech Z-2300 Computer Speakers
Left speaker terminal on the sub doesn't work properly
This is common with the type of powered speakers where the IC package that drives the speakers (the amp) is getting to hot and shuts down. Usually it is damaged and not reversable. There is a lot of reports of this same model loosing one channel or playing quietly. The air most likely cooled the chip down until it heats back up.
Jan 15, 2009 | Logitech Z-2300 Computer Speakers
Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's is located over the power supply connector.
Jan 12, 2008 | Logitech Z-2300 Computer Speakers
Logitech Z-2300 Computer Speakers Logo
310 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
