Question about Troy bilt Horse Roto Tiller Parts Manual Breakdown
Troy bilt horse tiller reverse does not work . whats the problem?
  • 4 Answers
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
Posted on May 05, 2009
  • 22 Answers
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
Posted on Jun 14, 2009
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Posted on Aug 05, 2009
  • 26 Answers
SOURCE: What year Troy Built Horse Tiller
The serial number is stamped on the upper right hand side of the gear housing. It is on a flat spot just above the wheel shaft. If it is a newer model it will be on a white sticker on top of the gear housing plate. If it has the T handle it is probably an older 1980's model. If you find the six digit number I can give you the year it was made.
Frank
Posted on Sep 14, 2009
SOURCE: how do i adjust belt on troy bilt horse tiller
How do I tighten a belt on a troybilt Tecumseh rear tine tiller?
Posted on Apr 12, 2011
Adjustment for belt for 8 horse power horse. Really need to find a manual. Where can I locate one?
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/21A682J766/Troy-Bilt%208%20HP%20Rear%20Tine%20Tiller%208%20HP%20680%20Series%20Briggs%20and%20Stratton%20Engine%20Manual/275092/
May 29, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
Pony size Troy-Bilt 30 years old\r\nQuestion; Can motor be replaced?
Yes but unless you purchase a engine with the two shafts, one for forward and one for reverse, you will lose your reverse. If you don't mind not having a reverse just go to a nearby Harbor Freight store or order on line a Greyhound 6.5 HP engine. these are Honda clones and run great they just had a sale here in Columbia Mo. and it was on sale for $99.99. I have used these on many of the Troy Bilt Horse tillers and they work great. They have metric threads and you may not be able to use your throttle cable but for the price you can't beat it.
Frank
Oct 03, 2010 | Troy-Bilt Pony Garden Tiller
Troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Aug 29, 2010 | Troy-Bilt Garden
How to attach hiller/furrower to troybilt horse tiller
how do you attach a furrower to a troy-bilt "horse" tiller
Apr 14, 2010 | Troy-Bilt Pony Garden Tiller
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Can i see the models from 1983 to 1985,i need a belt so i can use reverse again but i dont now my model or size. my husband died 3 years ago. if i could see some pictures from the 1980's mine has a potatoe...
Your question doesn't give enough detail to properly answer. Do you know if the tiller is a Horse model or a Pony model? Troy Bilt made both models back in the timeframe you noted. The Horse model had tires that required air to inflate. The Pony model likely had hard rubber tires in that era. The Horse models had a reverse disc, no belt. The Pony had a belt.
Once you know which model you have - look for your closest Troy Bilt dealer and see if they can track down the part for you. They might appreciate it if you could provide the serial number - which is located on the pipe connecting the tiller transmission front half to the back half, where the tines are located. It's stamped right into the metal tube on both models.
Jul 17, 2009 | Troy-Bilt Garden
How do i adjust belt on troy bilt horse tiller
May 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Apr 02, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt Horse Roto Tiller Parts Manual Breakdown Logo
229 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
