Question about Sewing Machines
How do I thread discovery kids sewing machine
Kids
4 Suggested Answers
SOURCE: How to thread a Kenmore Mini Ultra sewing machine
How to tread the sewing machine
Posted on Aug 23, 2011
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
When using the button hole attachment, my fabric is not moved forward by the lower plate and thread gets caught up under that bottom plate. How do I fix this
Perhaps you have the stitch length set too short (close together) so the thread under the fabric is building up into a knot and then hangs up in the space under the needle plate. Try lengthening the stitch length and do some tests until you get it where you want the buttonhole to look.
How to Make Buttonhole on Your Sewing Machine Sew4Home
How to sew buttonhole with an old machine
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Jan 30, 2016 | Sewing Machines
Stitch length singer
Run through the "10 minute tuneup" here: https://answers.yahoo.com/question/index?qid=20090925205957AAq0xc4 DO NOT MESS WITH THE BOBBIN TENSION. Top tension setting should be about 3-4. Stitch length probably in the neighborhood of 2.5 - 3.5 mm.
Little kids and sewing machines seem to have a natural attraction, which is why my mom taught me to sew on her machine when I was 5. Sometimes it's easier to teach the kid how to do it right than keep the kid from messing with the machine.
Jun 24, 2014 | Sewing Machines
I have rethreaded my machine and now the left needle thread isn't catching
Hai, Some times broken some small parts, wacher inside. So please check the left needle inside parts.
Apr 05, 2014 | Brother 929D Mechanical Sewing Machine
The thread from the spool breaks immediately. Does it need a particular kind?
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Oct 12, 2012 | PfaFF Sewing Machines
I have a brother ls-1217 i was cleaning it and one of the springs that is on the inside on the left came un hooked from the bottom and I am not sure where is supposed to be hooked up to. Can someone...
Brother says DO NOT OIL!!
Sadly I'm afraid you'll have to take this in to a service location.
Issues with thread jamming and threading are normally issues with the wrong needle for the application. Your manual should have needle suggestions for different fabrics. Also before you begin sewing grasp both threads and gently tug straight back as you start your first stitches.
Good luck.
Feb 05, 2011 | Brother LS-1217 Mechanical Sewing Machine
Lost manual to Totally Me Sewing Machine for kids. Where can I get a copy of one?
No answers????? Are you supposed to unscrew the protective needle cover and thread it before sewing??? This is really silly there are no instructions.
Jan 27, 2010 | Sewing Machines
Breaking needles bobbing in huge ball and thread not even
i cleaned and oiled it and it fixed itself.
Nov 15, 2008 | Sewing Machines
Sewing Machines Logo
4,066 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
