SOURCE: 6 beeps on start up, no video
Without knowing what yo have for a BIOS, it is difficult to diagnose. The below link is a list of beep error codes for different BIOS types. Check your BIOS to see if it is one on the list and see what it means:
http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=guide_beep_codes
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
SOURCE: I have the same problem 6 beeps...I green 3 yellow lights
That beep code indicates memory is not being properly identified or used. Try removing memory and testing with one module at a time until you find the one module or slot that is causing the trouble.
