Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
OMT Gripper Issue
I have a 1992 OMT1015 Wurlitzer. I had it in my storage for about a year. Now that I've hooked it back up, it won't put CDs back correctly. The gripper will take the CD and place it correctly. Then after the song is done it picks the CD back up correctly. BUT on the return trip the arm doesn't rotate back into the carousel position. It just stays flat. The CD hits the bracket that sticks up from a rod going to a switch. Then it just jambs. I can turn it by hand as it puts the CD back with little effort. But it just won't do it itself.
Any ideas? Thanks!
Larry
autopaint@inbox.com
  • Donald Steinback
    Donald Steinback Dec 21, 2016
    I have a OMT Wurlitzer 1015 holds 50 45 records it is doing the same thing the gripper arm doesn't rotate enough to get it back in the slot have you fixed yours yet Thanks Don
    Champion:
  • Wurlitzer Expert
  • 211 Answers
There's a spring wound round the shaft of the rod that drives the gripper gears. Oil very lightly. The gearbox rotates when it puts the arm back but the arm is held against the driving part by this spring so if it is sticking the arm will not turn over properly even if the drive shaft is doing what it is supposed to.
Dave.
Posted on Nov 03, 2008
Can't play discs
i can send you the manual to fix it
Sep 18, 2012 | Wurlitzer Jukebox 1015 One More Time...
I purchased a used Wurlitzer 1015, question When selecting number 51 is a code number 82 and does not play can you explain me this, what the problem is thanks
The number of Cds in the carousel can be set on the Credit unit to stop it playing fresh air if for example you only have 50 Cds and not a whole 100. Sounds like yours is set to 50 so won't play anything over 50.
I 'think' this is what you do.
On the computer credit unit...
Service Switch ON...Press LT button.
Press 5 on the keyboard once.
Enter 0000
Service Switch off.
Press LT or turn machine off/on.
Aug 03, 2011 | Wurlitzer Jukebox 1015 One More Time...
WURLITZER OMT CD 100 D picking problem
Hello J.P.,
You need to get the manual for this jukebox.
You have to however confirm what the manufacturer and the model number of this is. The One More Time was made by the following manufacturers:-
Wurlizer, Rowe Ami, Rock Ola, Antique Apperatus and Sound Leisure.
Look for a serial plate on the back of the jukebox in order to get any information.
You can get manuals in the USA from www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Nov 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
Hello, I have a problem with WURLITZER 1015 OMT CD 100D. The arm go to pick up the CD, but returns in the same time as it lock the cd in the gripper.Result is the CD is supported on two points instead of 3...
The carousel is locked in position by the latch at the front (about 6 oclock). If the gripper isn't exactly in line with the cd then you need to adjust the latch a bit.
Nov 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer OMT, takeout arm continues to cycle all the time
There is a white bracket on the far side of the gripper arm which comes loose so it doesn't click the microswitch beneath it. To prove this press o the bracket when the arm is over the cd magazine and it will stop.
Oct 11, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 OMT 100CD
I asked a Wurlitzer engineer about this problem and he simply said, "Bend it a bit."
Sounds horrible but there is no genuine adjustment. But before doing that, try moving the carousel lock latch (at the 5 oclock position). This is what locks the carousel and determines its position when the correct CD number is reached. If you could ****** or advance it a little it might work.
Dave
Apr 05, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
188 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
