Question about HP DV9410US Pavilion Notebook
Plugged in Not Charging - HP DV9410US Pavilion Notebook
  • Greg Willford
    Greg Willford Feb 11, 2012
    I just bought a new AC adapter, and a New Battery it is still doing the same thing except it is also shutting down by itself. It will sometimes work for hours, and then other times it just seems like you barely get it turned on and it shuts off.
  • 3 Answers
Got the presario notebook the pin is not recharging the battery cost tofix 200 $ get a quote from it guy
Posted on Feb 11, 2012
Plugged in,not charging
I think your battery is faulty. Not charging anymore has reached his lifetime. Replace the battery.
Mar 14, 2014 | Acer Aspire Computers & Internet
Plugged in not charging
On some devices, like my work Lenovo laptop, it'll stop and just trickle charge when the battery is at 97%. That's a feature, not a bug, designed to help avoid overcharging and damaging your battery and device. Try running on battery for a little while and reconnect the AC adapter. You should notice it's charging again. If it doesn't, post back.
Jan 06, 2014 | Intel Computers & Internet
HP probook 4540s plugged in not charging
Simply unplug the power from the adapter, leave for some minutes then reconnect.
Dec 23, 2013 | HP ProBook 4540s Notebook PC ENERGY STAR
HP Mini 2140 "Plugged in, charging" but not charging
Hello jorel, most likely its a failure of the system board particularly the charging section, a broken pin or a loose terminal. work will be internal, suggest you do away with the battery. its better to operate it at home, or bring the charger with you. Maybe its time to get a new one.
Dec 05, 2013 | HP 417035-001 - HP Pavilion dv2000 Series...
Plugged in but not charging... acer nplify 802.11
Is the battery good? A replacement battery? Remove battery and re insert. What indication gives you the idea that it's not charging? No charge light on? In software, the icon in tray notification area?
Nov 28, 2012 | Computers & Internet
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Huawei Impulse 4G
First, check to see there is no physical damage around the charging port, then if you have a AVO meter, check that the charging cord is actually putting out a current; then go to the BIOS and look inside. if you see
Adapter , Unknown device installed, that is your answer - it isn't a Dell charger. Now go to https://www.dell.com/community/General/Dell-Inspiron-1525-new-battery-not-charging-in-BIOS-showing/m-p/4709466
If that message is not there
1. Ensure that the battery is securely in the laptop and that none of the pins on the computer or battery are dirty.
2. Consider that there was nothing wrong with the old battery but the circuit on the motherboard that controls the charging is faulty - there is usually one chip that is at fault in this case.
3. The new battery is completely discharged: does the battery show signs of life when used without the charging cable? If it does, this is not the problem
Feb 01, 2018 | Dell Inspiron 1525 Laptop
I have just bought the acer aspire 5750 and had it for 2 days. I have just realised that my battery is not charging it says '0% available (plugged in, not charging)'. I have taken out the battery and
Exit windows and shut it down.
Leave it plugged in and it will start charging.
There is no need to charge the battery when in use as it knows it is connected to the mains power and only charges when shut down.
Feb 02, 2018 | Computers & Internet
Battery of laptop not charging
If the laptop works when plugged in, the power supply is OK. The battery controller is probably the problem, which would mean replacing the battery.
Apr 17, 2010 | Computers & Internet
HP DV9410US Pavilion Notebook Logo
43 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
