Question about Tunturi T30F Folding Treadmill
Won't fold up
Won't stay up when folded, is on 0 elevation
    Top Expert:
  • Tunturi Master
  • 12,223 Answers
Dear Sir:
Pleae read your instruction manual about how to fold your treadmill. If you do not have the instruction manual go: www.fitness.manualsonline.com and give your model and download for free.
Possible the pin is bent, you must need to rectify with a hammer with carefully. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 18, 2012
I can't fold my caddytek lite 11.5 v2 cart
I'm sure you figured this out by now, but for others stuck with the same question, here's how you fold it: the upper handle of the cart is 'locked' into place with the lower cart just above the upper bag strap. It's the same plastic piece that adjusts the angle/position of the handle. Slide this plastic piece back up the shaft (toward the ball holders), and the upper handle will release & fold down. The 2 side wheels also fold in at the same time.
Jan 21, 2013 | Caddytek CaddyLite 11.5 v2 Deluxe Push...
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 08, 2013 | Tunturi T40 Folding Treadmill
Rear seat on my Note won't fold down. When I pull the handle up nothing happens. Any ideas?
Are we talking about Nissan Notes here? I have the same problem with my 2006 Note where the larger of the 2 split seats in the rear won't fold down. It doesn't have any side latches or boot straps and yanking it hard doesn't work either. I can't see any options other than complete removal of the whole rear seat assemby.
Aug 25, 2012 | Nissan Note Cars & Trucks
Yukon xl 2009 passenger power fold mirror won't fold
the cable that controls the mirror is more than likely broken or if it's gear driven the gear is stripped or broke. I would first try to take the switch apart and clean it
Jul 14, 2012 | 2009 GMC Yukon XL
Quinny buz won't collapse
Hi
We wouldn't advise anything apart from cleaning the chassis, as a build up of dirt and debris on the chassis would cause friction and make it difficult when trying to fold. Clean with furniture polish or dry Teflon spray and a soft cloth - don't use an oil based lubricant.
Other than that we'd recommend you contact the customer care team at crelations@djgusa.com for assistance.
Jun 21, 2012 | Quinny Buzz 3 Travel System Baby Stroller...
Pram won't fold
Silicon Spray, Brute Force and Black Magic
Jan 01, 2012 | Bugaboo Bee Red Standard Stroller
I can't fold my treadmill back up. Instead of folding upright at the 12 o'clock position it is tilted to the 11 o'clock position. Any ideas why it won't go all the way upright?
1) SEE IF SOMETHING IS PENDING between the folding section
2) Your Pin is little bend.
3) the receiver where the pin is coming is not adjusted.
sincerely.
Sep 14, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
Elevation is elevating in the wrong direction
Unless this unit was physically re-engineered,either the rear end incline on some models or from the front depending on the mechanism look closely when you fold it up chances are you will be able see that mechanism thru the bottom cover slot made bigger for the rear wheels to move.
Apr 09, 2010 | Bladez Ion 9.9 Fold-up Treadmill
Tunturi T30F Folding Treadmill Logo
422 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
