Question about Rheem Pool & Spa
Rheem pool heater
I am trying to get spa to heat up for the first time. I have a Jandy remote and the front of the Rheem heater (model P-M336A-EP-C) says to hold all three buttons down to turn on remote, but this doesn't work. I have turned unit off for 15 min and back on and still no response.
    Scholar:
    New Friend:
  • 66 Answers
The display can be decieving when the remote function is turned off it will be in all caps like REM OFF but when it is on it will look like REM oFF. In the on mode the "off" is actually reading the heater mode is off (not pool or spa).
Posted on Feb 18, 2012
  • 128 Answers
SOURCE: We have the Jandy AquaLink RS PDA, we have two
If you have a spa side remote unplug it at the outside control panel. If the problem stops it's the remote
Posted on Aug 30, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 8404 Answers
SOURCE: Jandy Aqualink RS4 randomly turns on blower, pump, heater
Re program your assorted timer functions and make sure you set AM and PM or use a 24 hour clock. I think your model allows for a 24 hour clock setting but I am not certain.
I hope this helps you
a
  • 990 Answers
SOURCE: JVA 2440 rotates continuously in spa mode
If you remove the handel and open thr top of the actuator you will see a set nut on the center of the shaft that you use to set where the valve stops. If this is tight then you may have a bad micro switch in the unit and you should replace the actuator. Good luck.
Posted on Jan 20, 2010
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
Jandy one touch control panel model 8156 - spa turns on when pool is on
if you have a 4 button spa side remote unplug if it goes away replace spa side remote
Aug 03, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Heater manual for Rheem
Link to manual. You can also go to www.raypak.com this is the Rheem pool and spa product line. They just started using thier Rheem label a few years ago. Same heater. http://globalimageserver.com/fetchDocument.aspx?id=9858dad5-021a-4216-b0d5-1e29edd2f913http://globalimageserver.com/fetchDocument.aspx?id=9858dad5-021a-4216-b0d5-1e29edd2f913
Feb 11, 2012 | Jandy Pool & Spa
Need to replace gas spa heater. Is there a combination gas and solar spaheater
You may actually use any pool heater with a solar water heating array. I do not however know about any that come as a package deal. You will need a solar array, a solar controller, a actuating valve to hook to the solar controller, and a new bypass assembley for the plumbing system. All of this is made by manufacturers such as : Jandy, Pentair, Raypak, Lasco, Buderus, Hayward, etc....
Feb 16, 2011 | Solar Rheem Gas Fired Pool & Spa Heater...
I have a Rheem Raypack pool heater and cannot locate my manual. The model is pr266a-ep-c. Is there a way to get the manual?
If you run a search for Rheem or RayPak the site should bring you to a menu that will have most manuals.
www.raypak.com/uploads/6000.52AG.pdf
This link may help but I think it goes to an older heater, but it will give you a start.
May 08, 2010 | Rheem 266K to 399K BTU Swimming Pool...
I have a Jandy Laars LX Pool/Spa Heater...when I try to heat it cycles three times then tells me to call for service...I feel heat coming out of the vent. The pool/spa is connected to a AquaLinks system...
Mar 05, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
Jun 01, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Pool & Spa Logo
340 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
