Question about Olevia Televison & Video
The Tv keeps turning off every 1 minute or so
When it first turns on works for a minute or two then it shuts off. Subsequently when is turn on it shuts off apprx in 60 seconds
    Problem Solver:
  • 6 Answers
1) try going to the menu and search for power sittings and try editing them 2) open the catalog of the tv and see how to make go away 3)go to see some one professional to fix it but i do not think that some thing wrong with your tv exept the menu stuff so check it 4) try setting your tv to factory settings
Posted on Feb 12, 2012
3 Suggested Answers
SOURCE: i have a sony wega kdf e55a20 that keep on shutting on and off
I have had the same problem and found an at least temporary solution. On the remote under the slide there is a power save button, set your TV to reduced power and the problem shall not persist.
Posted on Jan 24, 2009
panchal643Ja
  • 243 Answers
SOURCE: My LG LCD HD TV keeps going thru the inputs like
Checked Source Button on LCD side Switch or your LCD Micom Board is defective
Posted on Feb 19, 2010
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
Our car alarm keeps going off. We turn it off and it goes off again in apprx. 5 minutes. We are in a cold climate, it is apprx. -19c right now.
There is an issue with the Body control module in those. Have your dealer check for codes in the bcm.
Feb 21, 2011 | 2011 Kia Sorento
I was working on facebook last night when my screen faded out then at the top of the screen everything started turning an aqua color with minute sized squares similiar to snow and it took over the screen. ...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
May 18, 2010 | HP Pavilion dv9000z Notebook
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
I have a recently purchased RS 2664 RCA shelf
If the wires got crossed and/or touched each other at all - that could certainly damage the amp(s).
Also - if the system is not made for extra speaker - that would change the ohmage - and that could aslo damage the amp(s)..
Or maybe the system designed to protect the amp(s) was damaged..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | Audio Players & Recorders
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
Set turns off on its own
when it shuts down press menu and input buttons both in together on the front panel and hold in for 8 seconds and see if the LED blinks a two digit code . If so let me know the number of blinks
Jun 17, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Televison & Video Logo
327 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
