Question about E-Machines eMachines Desktop PC
  • Anonymous Jan 30, 2009
    my system unit is on i changed the cables connected to the monitor but i get no signal out put thaks
  • 749 Answers
Signal lost usually means the cable is lose that connects the monitor to the back of your computer.
with the computer off and unplugged , disconnect the monitor cable from the video port on the back of the computer and physically inspect the pins to make sure they are not bent on the monitor end.
some monitors have the same plug on both ends , so it doesn't hurt to check the monitor side of the cable.
Once the cable has been checked, if the cover is off the computer, i would check all cables and add-in card to make sure they are fully in thier slots and ports.
check memory for the same issues.
If your monitor is a multi-function device , make sure you didnt forget to hit the source button on it , could be on the wrong input.
Posted on Oct 23, 2008
  • Jeff Strader
    Jeff Strader Oct 24, 2008
    If the hard drive activity light is staying solid, its showing you that something is keeping it busy.
    this could be a virus scanner set to run at startup, a program or virus, or windows try to check the system or hard drive.
    tell me, when you replaced the hard drive, is it internal or external? Did you set the jumpers correctly on the hard drive? Are all cables connecting the hard drive and other devices inside snugly in thier slots? Is the RAM seated correctly or the video card loose in it's slot?
    pull the cover back off the computer and physically inspect these things.
    we have to get a picture before we can work in the operating system.
    then post again here and we go to another step.
2 Suggested Answers
  • 164 Answers
That problem would either be with your video driver or your video card or both.
I suggest looking up your audio device whether it be a card or onboard.
If its onboard, the manual for your motherboard will have it.
Update the drivers.
If its the video card faultering, i suggest buying a new one that fits your motherboard.
The socket size for your video card will also be found in your motherboard manual.
Smart disk check error
Hi Jason,
I see you get an Error Smart Disk check error.
on your machine try to boot into safe mode with command prompt, as soon as you power the system on keep on tapping F8 this should give you the list that will prompt safe mode options. Select Safe Mode in Command Prompt, Once you have the Command Prompt go and type in chkdsk /r then press enter it may take awhile before the checking finishes but once it is done it will show a bunch of stuff regarding the Disk check, restart your computer and see if it will boot back into window,s if it does I suggest that you go and back up all of your personal data on your Hard Drive just to be on the safe side, the Error you got give an early warning that your hard drive is actually experiencing errors on it and may stop in the coming days I cannot tell when but it is better to have saved any personal stuff that you need that having it lost once the Hard Drive stops to work.
I hope this helps.
Oct 22, 2012 | HEWLETT-PACKARD HP Pavilion dv7-4285dx...
Dell Precision M90 no boot and device status light next to power light is green
Here are Few steps which can use to trouble shoot your laptop no display problem.
1. Connect a VGA
cable for external monitor and check if you can see any display on External Monitor.
2.Take out your RAM and Clean it with Pencil Eraser and Put it back. If Possible try with different RAM,
3. Remove your Hard Drive and Try switching on Laptop without the Hard Drive.
4. Make sure that you are using proper Adapter with proper Voltage.
Aug 10, 2012 | Dell Precision M90 Notebook
My acer travelmate 6292 suddenly hang and when i reboot it blank screen appeared
test all power and data leads that attach to your hard drive the leads from your
(motherboard to your hard drive) Sata make sure they have dust free secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as a faulty fan lead can cause you problems a computer needs all of the power and data to travel through every working device and to
have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
then try it if it does not work
try in safe mode
you might need to get rid of the virus first
or try safe safe mode to download or run your antivirus software
or even safe with a system restore
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Return to OS Choices MenuSelect safe mode with networking to download
anti virus and malware
your operating system must be registered and activated
microsoft security essentials
Anti-virus and anti-spyware solution Xp
Anti-virus and anti-spyware solution windows 7 64 bit
you could download and run just the Anti malware program or any other you might need
after you have run the Anti malware program
hope this helps
Aug 04, 2012 | Acer TravelMate 6292 Series Laptop Charger...
Whenever I connect any removable drive automatically 4 shortcuts got created of control panel.
You have a virus on your PC. Unfortunately, once you have this virus, it usually does not help updating your anti virus and running a scan since the virus is running in the memory of the PC and every infected file the anti virus removes - the virus just puts back again. Try one of two things to remove the virus:
1] First update your anti virus (if you dont have an anti virus, download the free AVG Antivirus and install that and then update it. Click here to go to AVG's website. Once installed - Boot your pc into SAFE MODE. This is VERY important otherwise the virus will load into memory and it wont help running the anti virus to clean the system as the memory resident virus will just replace any infected file that is removed by the scan. To boot your PC into safe mode: Read this article: Click here.
Once you are in safe mode - Open the Anti-virus console and do a complete system scan.
2] Remove the infected hard drive from your PC and install it as a secondary drive in a clean, VIRUS PROTECTED PC!!! ... i.e .. any pc that has the latest anti-virus system installed and is up to date!. Once you have installed the infected drive in the protected PC as a secondary drive, run a scan on the infected drive and remove the virus.
Once you have removed the virus, also scan ANY USB devices on that PC, including any Cameras, cellphones, photo frames, etc that you might have plugged into the infected PC.
Good luck
Feb 07, 2011 | Computers & Internet
Computer turns on, no signal to lcd. Hard drive
The blue screen was caused by corrupted drivers or a virus that was corrupting the drivers. Have you tried starting the machine in SAFE mode? To do this press F8 while the computer is starting before Windows loads. You should get a menu with several SAFE mode choices. Select SAFE mode and continue. If the computer works fine at this point, I suggest downloading the following AVGFREE.exe, MALWAREBYTES.exe and SUPERANTISPYWARE.exe. Run these to absolutely eliminate any chance of a virus. Once done go to START, Run and type SFC/scannow. You’ll need to have your original CD’s handy. This will replace any corrupt drivers. Now, what to do if you can’t get into SAFE mode. The question then is anything showing on the screen? If nothing but you can hear the fans but no beep codes I suggest you take the laptop to a reputable repair person or check my website Good luck.
Mar 01, 2010 | Computers & Internet
I powered down my computer because I couldn't get my mouse to work. When I powered it back up nothing booted up! The lights are all on and fans are running, but the monitor isn't getting any signal from...
I beleive that this is a virus. some Viruses corrupt the device settings on a mouse or keyboard. you will to try to boot the computer in safe mode. to this when you tun the computer on press the F8 btton on the keyboard. then select safe mode with networking and hit enter. when the computer boots up you will need to run a virus scan. another option is to take the hard drive out of the computer and put it in another computer and run a virus scan on it. Viruses that usually cause this type of problems are redirect viruses found when searching on google.
Jan 09, 2010 | Compaq Presario SR1000T (568657) PC...
My computer is infected with lasa.blaster.keyloger and i cannot activate any programs except the internet. can uou help? Is there aan answer? I can not get my e-mails.
Reboot in safe mode (this is done by restarting the computer and pressing the F8 key, which will give you a list of bootup options. Select Safe Mode.) From safe mode, download the following anti-virus programs: AVG, Spybot Search and Destroy, and CCleaner. All these programs are free, very effective, and can all be downloaded from Once they have been downloaded, install them and run scans. All three should get the virus out.
Nov 23, 2009 | Computers & Internet
Update the drivers.
Oct 23, 2008 | E-Machines eMachines Desktop PC
Computer laptop problem
Generally, when a firewall or antivirus application fails to load, a virus is the suspect cause. Many viruses are designed to attack/disable the firewall/antivirus as to infect the system. If the operating system has beenn compromised to the point you can only boot in the safe mode, the likelyhood of removing the viruses and still being able to repair the operating system WITHOUT a clean reinstall of Windows is not great.
Things you can try.
  1. If you have more than one computer, see if you can connect this drive to a healthy system, and remove the infection.
  2. Run hardware diagnostics on the hard drive, as a hardware failure can mimic a software problem by files being damaged writing them to bad sectors of the media.
  3. If you can access the internet in safe mode with networking, or can access internet with another system, you can download several programs/tools to try to remove any infections. www.gur,in is one page with a large assortmant of tools to try to use to remove any infection. Sometimes you can install and run these in the safe mode or use safemsi.exe to enable some installers to run in the safe mode.
If the hard drive fails diagnostics then you will have to replace the hard drive. If it passes diagnostics, and attempts to remove infection fail, boot to XP cd, format the hard drive and do a clean install of windows the reinstall all drivers and applicaitons. If the format fails, replace the hard drive
Jul 06, 2008 | Gateway Computers & Internet
Xp wont start on sony vaio v94vq
Try booting into safe mode completely. Then shut down completely. Unplug for a couple minutes and plug back in and see if it will boot normally. If not, then go back to safe mode and use a restore point in XP. If that does not work then either XP is corrupted or the hard drive is going bad. You can try restoring your system with the restore discs. NOTE: This will erase all data, pictures, letters, financial info, etc. you have saved.
If that does not work then you can try replacing the hard drive.
Hope this helps!
Nov 28, 2007 | Sony VAIO PCV-J200 PC Desktop
E-Machines eMachines Desktop PC Logo
83 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
