Question about JVC XL-F254BK 5-Disc CD Changer
No power I pushed the power button, the display flashed for a second, went off, and now there is no power at all using the power button or remote. I checked to see if there is any fuse or circuit breaker and there appears to be none.
0 characters
1 Points
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | CD Players
When the switch on the system after 5 seconds hangs the device and display, "protect push power" push to reset.
Apr 21, 2012 | Sony CD Players
Record button will not push down with play button, to record.
Are you using a new cassette???? Check to see if the tab is missing on top of the tape.....If it is put tape over it
Mar 14, 2012 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Hi we have a Sony CD-E550 3 disc changer and I am trying to set the clock. No idea how to change the time. Additionally is there a speaker balance mode thanks
hi use your remote well i find it easier using it this way...on the remote push the menu button...scroll up up or down and find the setting for the clock display on or off....still using the remote push the sound button scroll through and you can adjust the settings there.... hope this helps
Dec 05, 2010 | CD Players
CDJ1000 MK2 Powers up but no display & no sound
Had the sam problem... Turn te player upside down, take off the bottom cover and check the semiconductor fuses located near the supply connector on the top of mainboard. The one that is responsible for display is marked as VLOD (-40V). Worked for me :)
May 15, 2009 | Pioneer CDJ-1000 CD Player
SONY NAS-EH35HD Giga juke hi fi Standby light flashing
i have similar. All gone off and red light flashing. Did you get yours sorted?
Mar 27, 2009 | Sony CD Players
Setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Dec 15, 2008 | Denon CDR-M30 CD Recorder
Sanyo dvd player model no. DWM -360
You can find the remote control codes for different brands of devices from
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
Hope that helps! Should you have any further questions, please feel free to post them here.don't forget to rate as ...
Jul 18, 2008 | CD Players
Pioneer xc-f10
switch the unit off
With the unit off press the menu button
The Unit now switches on and
you will now be presented with DEMO mode on the Screen
Press the + on the remote
The screen will now display Sensor Mode
Press Set
Press + twice until Sensor Off is displayed
Press Set
Unit switches off
Jun 15, 2008 | CD Players
Tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Dec 27, 2007 | CD Players
JVC XL-F254BK 5-Disc CD Changer Logo
23 people viewed this question
Top JVC CD Players Experts
Josh Whitehead
Josh Whitehead
Are you a JVC CD Player Expert? Answer questions, earn points and help others
