Question about Ricoh Office Equipment & Supplies
Ricoh Alficio SP C811DN error code SC290
I was printing and a paper jammed coming out of the printer. I removed the jammed pages, closed the doors and then received an error code SC290.
  • 37 Answers
SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Posted on Nov 16, 2007
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
SOURCE: page counter on RICOH aficio SP C811DN
Enter the menu of the printer pressing once the relevant button and with the up or down buttons find the list test print. Then press once # or OK (whatever the machine has) and you see Configuration page. By pressing once again the # or OK it prints the Config.Page, which somewhere on the top of thw sheet shows the pages printed (first the black and then the colour. Good luck!
Posted on Sep 09, 2009
newport74
  • 58 Answers
SOURCE: My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Posted on Feb 26, 2010
newport74
  • 58 Answers
553 is:
second.
�� Defective PSU
�� Defective IOB
�� Defective EGB
These codes related to the fuser a designed to prevent a fire
I would recommend haveing a tech look at it
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
RICOH AFICIO SP C811DN
press the up/down arrows together for @ 5 seconds, then hit "ok".
scroll to "engine"
look for 5-810 -SC reset, hit "OK" turn machine off/on using toggle switch.
May 09, 2014 | Ricoh Aficio SP C411DN Laser Printer
Ricoh SP C811DN has a sc 400 error code
open the front door and left door, take out the drum unit after releasing the lock lever if look at the opening from the right you can see a black sensor unit facing inward towards drum clean its inner side with a dry cloth and put back everything it is the id sensor, machine should work now
Apr 03, 2014 | Ricoh Aficio SP C811DN Laser Printer
We have an SC548 code on our Ricoh3500
"Fuser not installed error code". Did you have a paper jam in the machine? If so open the right door and make sure that the fuser unit is correctly set. You have two tabs on the end next to them are levers lift them, then pull on the tabs "C1" fuser unit(unit that gets hot) pull on them then the unit will come away from the machine slide it back into the machine making sure not to slam it. Close the machine.
To reset the error code go into service mode "clear 107 stop hold the stop down for 5 seconds" select copy SP then 5810# execute then restart machine. Hope this helps.
Nov 10, 2013 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio SP C811DN Printer. after printing 9 pages it will stop and displays CS367 error code saying 'Functional problem turn power switch off then on. Can you tell me what that means and how fix...
SC367 is a toner density error having to do with yellow. If you've tried turning the machine off (with the power switch on the lower left side) and turning it back on and that doesn't help, your next move should be to replace the yellow photoconductor unit (PCU).
Thanks for using FixYa!
Feb 08, 2011 | Ricoh Aficio SP C811DN-DL Printer
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Apr 29, 2010 | Ricoh Aficio SP C811DN Laser Printer
My Ricoh Aficio SP C811DN-DL Printer smudges bottom of the page each time I print. It's a 3cm wide stripe of colourful smudges running across the bottom of page.
Transfer belt cleaning unit. The transfer unit is above the drums and the cleaner is on the left side. Remove it and I would bet you see a similar band as what your seeing on your prints. You can try wiping of the cleaning blade in the unit or you may have to replace it.
Dec 23, 2009 | Ricoh Aficio SP C811DN-DL Printer
The bypass tray is contantly jamming when we try to print.
Hi, i'd start with cleaning any rubber rollers in the paper path, if its picking multiple sheets and then jamming, it will need a pick roller and seperation pad, hope this is helpful ,M.
Jul 03, 2009 | Ricoh Aficio SP C811DN-DL Printer
Problem with printing document footer text on RICOH SP C811DN
Check the paper size settings and orientation of the driver from the Control Panel, and that match to the paper size in the printer's trays.
Good luck and please rate me, thanks.
May 28, 2008 | Ricoh Aficio SP C811DN-DL Printer
No.
Type
553
A
• Defective PSU
• Defective lOB
• Defective EGB
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
Nov 11, 2007 | Ricoh Aficio SP C811DN-DL Printer
128 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
