Question about Fujitsu Computers & Internet
I don't know how to exit number lock on my laptop
I am not sure how i got into number lock but now i want to exit, i couldnt find the number lock key. Now when i type i have to hold on to the Fn key so the letters doesnt turn into numbers.
    Master:
  • 388 Answers
Push the FN key and the lock key at the top of the keyboard it will have a padlock on it with out the make n model i cant tell you which key it is
Posted on Feb 11, 2012
Nitrotrike
  • 589 Answers
SOURCE: Panasonic Toughbook CF-51 laptop blue FN key locked on
Hit "FN" and the "NUM Lock" key together to unlock it.
I believe thats the combination.
Let me know.
Posted on Jan 09, 2008
  • 3 Answers
SOURCE: function keys
Hi you need to hold down the function key (FN) and press the number lock key (num lk). hope this helps
Posted on Jan 14, 2008
SOURCE: FUCTION BOTTON STUCK, HAVE TO PRESS FN BUTTON TO TYPE
I have the same problem on my Dell Latitude CPx as what hebert9588 describes. I've been ignoring it for years using an external keyboard but finally tried different things (changing BIOS settings as well as this Fn+F12+NumLk that jackie1969uk describes in http://www.fixya.com/support/t1629106-fuction_botton_stuck_press_fn_button and it's healed! Thank you!
Posted on Apr 12, 2009
ebay312
  • 118 Answers
SOURCE: FN + F11 "turned on" at boot up
This feature is turned on and off in the system BIOS.
During startup, hit either the DEL or the F2 key to enter the setup.
Read through the items found there until you find the keyboard options.
good luck.
tony
Posted on May 19, 2009
virtualhost
  • 2185 Answers
SOURCE: when typing along the keyboard qwertyuiop, the
This means that NUM LOCK is set to on. All you have to do is to press the Fn key and then locate the NumLock key and press it. The num lock is usually also highlighted with the same color as the Fn key.
Please comment back if you still have issues. I will be glad to assist you further.
Posted on Aug 06, 2009
I don't know where num lock is
The NumLk key and ScrLk key are the same key and is located above and near the F10 F11 function key. Hold down the Shift key then press the NumLk key
When the NumLk is pressed the a LED Number lock will light up.
Nov 21, 2012 | Dell Latitude E5420 Computer (blmcj3b) PC...
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
Toshiba Satilite Pro will not boot up
Make sure that you have nothing in any of the drives. Then, when you restart it, go into setup. Be careful not to change things that don't need to be changed!!!! Look for BOOT. once you find that, change your Hard drive to the FIRST BOOT DEVICE. After that, exit saving changes and then reboot and let me know what you get.
With your preticular sittuation, there could be a number of things wrong.
Jun 12, 2012 | WYSE Computers & Internet
How to change the rear Hub Assembly on a 2001 dodge caravan
To be honest if you did know who to do it in the first place I don't think it's safe that you should be doing it, a rear hub with abs sensors can have alot of problems ie if you damage the sensor and the abs kicks in while driving down the motorway doing 70 your back wheel locks up fish tailing you out of control and smashing you and other cars up, you don't fix the hub back onto the axle at the correct torque causing your hub to come loose and detach, you don't connect the brake lines up causing air in the system and the rear shoes/pads not to grip..... All faults that could and have happened to people because they thought they could do it on there own
Apr 05, 2012 | 2001 Dodge Caravan
DELL INSPIRON 1525 HELP
It should be a simple fix. Start your laptop and pay attention to the screen. Press the F12 key (or F11) to enter "SETUP" then find the NUMLOC command and make sure that its DISABLED or OFF. This will turn this option off andyou will only be able to use the number's keys on the top of the keyboard. Be careful when entering SETUP. You don't want to change anything you don't have to.
Dec 26, 2011 | Dell Inspiron 1525 Notebook
I can't update my graphic??
Are you sure the graphics are a RADEON 200M? I don't think AMD Radeon has a graphics adapter called the 200M. Is this graphics adapter in a laptop by chance?
I know NVIDIA has mobile graphics (for laptops) that is a 200M.
Head over here to the NVIDIA wesite.
Product Type: GeForce
Product Series: GeForce 200M Series.
OS: Your Operating system.
Langueage: Your language
Then click search.
Dec 09, 2011 | Computers & Internet
It dont accept my password
Firstly, try the obvious. You don't have your caps lock on, or if you are using a smaller keyboard laptop, you don't have the number lock on. If not, then it's possible your account has had its password changed.
You can go to http://www.facebook.com/reset.php to reset your password.
Jul 23, 2011 | Facebook Social Network
I want to block one particular phone number from texting and calling me - how do I do this on the LG GW620
If you don't want to receive text or call from a particular person try this 1. ignore that person don't read his incoming message if only you can do that but make sure you memorize his number or assigned a code so that every time he text you already know who he is..2. If you don't wan to receive calls from that person if you that he is calling don't answer his calls or divert his calls to other number so every time he is calling his calls diverted to other number if you have a police number divert it there..and for the worst 3. Change your number and make sure he will never know again your new number so he won't be able to bother you again.. Hope it can help you..
Jul 06, 2011 | LG GW620 Cell Phone
Computers & Internet Logo
371 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
