Replaced the thermistor for pf light. ran for 5 loads to dry. Now there is no power on panel and inside dryer light is not working. I rest breaker and unplugged, still no power on panel.
SOURCE: Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
SOURCE: Kenmore Elite keeps tripping circuit breaker and small flash
Hello jaybebo84,
May be coincidental that you had a short circuit ocurr in the back panel after your wife dusted but the problem is that you now have a short circuit which will trip the breaker. If you can unplug it and slide it out to gain access to the back panel, remove the cover and look for carbon or flash burn on some of the components in that area. Usually when you get an arc like that the evidence of the component is pretty easy to identify. You may see some carbon or equivalent on a component which once located, could simply be removed and replaced. Sears usually has exploded views drawings of all their appliances and you may be able to get a copy from the store service area. Good Luck..
Regards,
Rick
SOURCE: Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
SOURCE: dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
SOURCE: dryer won't start
Check the plug, both the male and female side. Sounds like a loose connection. Check the connections going in the back of the dryer too...remove the little plate (with it unhooked) and check the tightness of the wire.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
